Automotive Forums .com - the leading automotive community online! Visit IgorSushko.com and see what it's like racing in Japan
Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Chevrolet > Blazer > Problem Diagnosis
Old 01-09-2007, 10:22 PM   #1
paxfam1
paxfam1 Normal reputation
Heater Problems???
Alright, 1998 blazer
The other day after I got out of my truck from a short trip to town I parked in my shop, and noticed a good sized puddle of fluid, so i felt it and it looked like water but was a little thicker and smelt some what like anti freeze. Been fine for a couple days but today coming home from work the heater wouldnt work. The fan was cranked and and blowing cool air. Then I turned it off for a few mins and turned it back on and all the sudden blowing hot air again, but only laster like a minute. Now I noticed this before that when I turn it to floor defrost, the fan turns off and nothing happens but when defrost on the window the fan runs. So as of now I have no heat and the floor setting dont work.............What you think is wrong.
paxfam
paxfam1 is offline   Reply With Quote
Old 01-10-2007, 04:01 AM   #2
muddog321
AF -Advisor
muddog321 Normal reputation
Re: Heater Problems???
If the coolant dropped low then the core maybe full of crap now so flush it and hope it doesn't leak. Also check the vac lines under hood on drivers side as the final connection is to the plastic line to the heater controls. Find the leak now so you don't destroy the engine - core, hose, waterpump, lower intake gasket or radiator.
muddog321 is offline   Reply With Quote
Old 01-10-2007, 08:24 AM   #3
paxfam1
alrighty.............Checked coolant lvl today and found it to be way low............ So chances are this is my problem. Would it be a good idea to flush the core anyways? I dont want it to start leaking though, do you just pull the lines off of the core and run water threw them? How do I even start looking for a vacume leak????
Old 01-10-2007, 09:19 AM   #4
Chris Stewart
AF - Advisor
Chris Stewart's Avatar
Chris Stewart Normal reputation
Now you must locate the leak. I put a large enough piece of cardboard under the front of the car to catch anything from the motor after driving it around enough to fully warm up.
Chris Stewart is offline   Reply With Quote
Old 01-11-2007, 06:41 PM   #5
paxfam1
alright found the leak, its coming from the water pump...............I was able to touch that seal thats between the pump and the plate thats on the back of it, and I think its leaking there. The seal is wet/soggy, and where that seal is dry its very brittle. So I guess I will have to tear this beast down, and I will just throw a new pump in, autozone has remans for 35 bucks. How do I go about removing the old pump, remove radiator ect............
Old 01-11-2007, 06:46 PM   #6
blazee
I'm gonna punch yo momma.
blazee's Avatar
blazee +50blazee +50
The anwer's in the How-to section:
96+ Water Pump Replacement
Like this post? Hate it?
<----- Click the and tell me what you think.
blazee is offline   Reply With Quote
Old 01-11-2007, 07:34 PM   #7
paxfam1
Is that a common place for them to start leaking?????? Just woundering why that back plate is even on there?????
Old 01-11-2007, 07:37 PM   #8
blazee
blazee's Avatar
Actually, there's a weep hole under the water pump that normally leaks. The coolant then runs back and makes it appear as though the plate is leaking. When you get the pump off, you'll be able to see the trail of coolant from the weep hole to the plate.
Old 01-11-2007, 08:29 PM   #9
paxfam1
So what your saying is that the pump is actually internally damaged.........Why would they put a weep hole there?
paxfam
Old 01-11-2007, 08:44 PM   #10
blazee
blazee's Avatar
It's there as an early indicator of problems. It tells you that the seal inside is bad and the bearings are compromised.
Old 01-13-2007, 08:12 PM   #11
paxfam1
Replaced water pump today, leaks gone and heater is working excellent!!!!!!!!!! Thanks boys!
Bookmarks
Google
Web AF
