01-08-2007, 04:41 PM
99 silverado check oil level
I keep getting these CHECK ENGINE OIL LEVEL messages and I cant seem to get rid of them. The level is perfect, but that is just going by the dipstick. I thought maybe because it was started cold, but now it happens when the truck has been running 30min+. Any ideas?
01-08-2007, 04:56 PM
Re: 99 silverado check oil level
Are you sure it's "Check engine Oil" Not "Change Engine Oil"?
Try going out putting the Key in the run position, pressing the gas 3 times quickly in succession Turning the truck back off.
Open your door, Close your door, then try starting it back up again and see if it does it again.
Just a thought anyways....
99 Silverado, 3 Door, Whistler/Blackcomb Special Edition
Magnaflow Single in Dual out Exhaust w/Flowmaster Resonator,
AEM Brute Force CAI,
Modded Automatic Headlights,
4 Headlight Mod,
Hella FF100 Driving lights
Green LEDs in Headlights,
Clifford Alarm,
Silverstar Low, XENON High Beams
NWSilverado
I AM Canadian!!
01-09-2007, 06:01 AM
Yep, im positive that it says check engine oil level. I have reset it twice, but the message still pops up.
01-09-2007, 03:15 PM
You may have a bad oil pump or a bad sensor. I would get it checked out right away.
2000 Silverado Z71, 5.3L, K&N GenII Air Intake, Y-pipe Exhaust (no muffler), Bosch Platnium +4 plugs.
01-09-2007, 03:37 PM
yah if you reset it there is another sensor telling you that..you might want to check oil sending unit or pcv valve....good luck.....
SCRAPPER......
01-09-2007, 10:57 PM
I had the same issue with my 99. Oil level is fine, as well as oil pressure. At the same time I was having this issue coincidentally my battery died. I had it recharged and put it back in and now I dont get the warning. I'm not saying your battery is going to die, but pulling the battery made mine go away. Hopefully it stays gone and doesn't result in something even worse down the road.
______________________________
2000 Silverado 4.8L V8 (Converted from 4.3L V6)
Edelbrock Ceramic Coated Headers
K&N Fipk Gen. II
Superchips MAX Tuner
Flowmaster 40 Series DF w/3" pipe
Poweraid TB Spacer
Flex-a-lite Electric Fans
3.73 gears w/Eaton posi
Whipple on hold
And those are just the performance mods...
