Automotive Forums .com - the leading automotive community online! Visit IgorSushko.com and see what it's like racing in Japan
Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Chevrolet > Cavalier
Old 01-08-2007, 02:09 PM   #1
dallas121469
dallas121469 Normal reputation
Send a message via Yahoo to dallas121469
Hub assembly replacement issues.
97 Cavalier
Well. Got the spindle nut off easily enough but the rotor would not come off the hub. Banged away with hammer/sledge for a bit and it popped off. Except part of the hub assembly and inner bearing races came with it. So now the remainder of the hub assembly is rusted in so bad I dont see a way to get it out without doing major damage to the CV shaft. Yes, I have also removed the 3 Torx bolts. I dont quite understand why Chevy didnt put the bolts holding the assembly in through the back like every other car I've worked on. Makes it relatively easy to pound out with an air chisel with the proper adapter.
If anyone has any incites it would be greatly appreciated. Thanks.
Steve
Nevermind. I just removed the strut bolts and steering linkage and pounded away at the back of the bearing assembly. Still wasnt easy but it eventually came out.
dallas121469 is offline   Reply With Quote
Old 01-08-2007, 04:41 PM   #2
Classicrocjunkie
Boosted Grocery Getta!!
Classicrocjunkie's Avatar
Classicrocjunkie Normal reputation
Send a message via AIM to Classicrocjunkie
Re: Hub assembly replacement issues.
Could have tried this...
Get a torch and heat it for a fit. Hammer and a pry bar. The whole hub assembly mounts flush to the steering knuckle. You just need to get something behind it and it should pop off. When you hammer on the rotor, you should have done it between the wheel studs instead of whaling on the outter portion which i am going to assume you did.
Please don't PM me with your J-body Issues. Post appropriately in the forums,
and I will toss my opinion in your thread if I have anything to help. - Thanks!
2004 Pontiac Sunfire Coupe SE Getrag 5 speed
2009 Subaru Impreza WRX 5-door
www.Rdfabs.com
Classicrocjunkie is offline   Reply With Quote
Bookmarks
Google
Web AF
