94 dodge dakota coolant leak
gary wilson
01-06-2007, 08:17 PM
I have a 1994 dodge dakota with a coolant leak that pours out the bottom of the motor. the leak is coming between the front of the oil pan and the bottom pulley. would anybody have any suggestions on what the proccess would be to repair this trouble? thanks
rhandwor
01-07-2007, 09:47 PM
I think you have a leaking water pump which is dripping down and coming around the crankshaft pulley. Look above the pulley about the center of the engine. The water pump has a drip hole which is probably leaking heavily.
The water pump has a pulley on it.
Otherwise you probably have a cracked block.
