Automotive Forums .com - the leading automotive community online! Visit IgorSushko.com and see what it's like racing in Japan
Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Chevrolet > Astro > M Bodies
Old 01-05-2007, 02:54 PM   #1
barry99astro
barry99astro Normal reputation
99 astro wont start
kids ran it out of gas and now it wont start, put 4 gallons in, sounds like it wanted to catch a couple of times, but it wont, any ideas?, thanks
barry99astro is offline   Reply With Quote
Old 01-05-2007, 06:39 PM   #2
ericn1300
AF Premium User
ericn1300's Avatar
ericn1300 Normal reputation
Re: 99 astro wont start
check your fuel pressure to see if they fried the fuel pump. the gasoline acts as a coolant for the pump and when you run out of gas the pump can overheat and fail. the more they tried to start the vehicle when dry, the more likely they ruined the pump.
ericn1300 is offline   Reply With Quote
Old 01-05-2007, 10:55 PM   #3
Blue Bowtie
Registered Offender
Blue Bowtie's Avatar
Blue Bowtie Normal reputation
You might also want to check the filter. As the pump sucked the last little bit of liquid fuel from the tank, it likely also got all the debris, moisture, and sediment that had accumulated in the tank over the years. If it didn't ruin the pump, it will have at least slugged the filter with a load of sediment. Even if the pump is bad, the filter will need replacement, so you might as well start with that then check pressure.
Blue Bowtie is offline   Reply With Quote
Bookmarks
Google
Web AF
