97 s-10 4.3 litre intake leak
reubenator
01-04-2007, 09:56 PM
I have a 97 s-10 w/ a 4.3L that the intake is leaking on. My question is do I need any special tools to disconnect fuel lines for fuel injection and will I need to remove the distributor to remove the intake? HOW DIFFICULT IS THIS AND APPROXIMATELY HOW LONG SHOULD IT Take?
Jari
01-05-2007, 07:39 AM
No special tools needed. You don't have to remove distributor. You may find this useful.. http://www.automotiveforums.com/vbulletin/showthread.php?t=559014
http://www.bittitalo.fi/blazer/intake.JPG
http://www.bittitalo.fi/blazer/intake2.JPG
DINO55
01-05-2007, 08:28 AM
Are you talking about the upper intake or the lower intake manifold?
reubenator
01-05-2007, 09:41 AM
I'm leaking coolant so I am assuming just the upper. Am I right?
DINO55
01-05-2007, 10:30 AM
Coolant leaking will be the Lower Intake Manifold Gaskets. It's a very time consumeing job. Not a lot of skill to it. Mostly common sense. I just did my 98 last month. Some things you may want to consider while doing this job. change all hose's, new 195 thermostat, and a new water pump and you MUST change the oil. You may need to buy some tools to make it go a little more smoothly. Are you going to be doing this yourself? If so, I followed this guy's instructions (link below) pretty much to a tee and the end results were perfect. Plus I learned a few tricks along the way that turned out to be big time savers..... Let me know if your intrested in them...
Takes a min to load the pictures...
http://d-tips.com/general/articles/Content/Article13.aspx
Good Luck
Dino
MT-2500
01-05-2007, 10:41 AM
As said the lower intake is where the intake leaks.
But double check for sure where it is leaking.
Check heater hose and hose connections and all other stuff first.
A good pressure test helps pin point the leak.
