Gas Leak Dash Lightslongfellow 01-04-2007, 10:56 AM On the 2000 Jeep Cherokee Sport I have' sometimes when I return to vehicle I pick up a very slight odor of gas. As if there was a gas leak somewhere. I have checked ground appearances under Jeep also fill cap pipe and gas cap area and see nothing. This is a now and then thing that I notice this. I also was wondering how this sealed system works because if your gas cap is not on tight then your dash indicater trouble light can come on. Can a minor gas leak somewhere in fuel system cause same effect? Note the odor when picked up is near back of vehicle and seems to disipate quickly. Any ideas . AlohaBra 01-04-2007, 01:09 PM Have you change the fuel cap? It is only $15 (I use a locking one). Then tighten the hose clamps under the fuel filler after you take the shield off. Stick89 01-05-2007, 04:18 AM Multi port fuel injection?....one or more injectors could be leaking..could be caused by o rings or injectors are leaking Throttle body fuel injection?....only 1 injector..on the throttle body...could be leaking... Carbed?....fuel leaking a carb... Starting from the gas tank...check all hoses and clamps....follow the fuel line all the way to the engine compartment...There may be "quick connects"at the fuel rail....these have o rings that have been known to leak..the quick connects can also be replaced...get em at most auto parts stores.. Fuel leaks are not something you want to guess at.... Automotive Network, Inc., Copyright ©2012
