Truck is flooding when i step on the peddlestillmanm 01-04-2007, 10:55 AM I have 97 GMC Sierra 2x2 6 cyl truck. The truck will start and sounds great at idle and even runs fine with a little pedal but when you rev it either while in park or driving it floods and boggs down. Any idea what this may be. I know the fuel pumps on these things go often but would this be a fuel pump issue. Thanks for any and all help. Mark Low-Low-SIERRA 01-04-2007, 11:21 AM I am having the same problem. This started after I changed the fuel filter. Thanks in Advance. Low-Low-SIERRA 01-04-2007, 03:34 PM Stillman. I'm having my fuel pump changed as I speak I will let you know if that is what caused the problem. maxwedge 01-04-2007, 05:47 PM I'd have the fuel pressure tested and check the cpfi unit for a bad press regulator or bad injector poppets, common problem with the Vortech. E B 01-05-2007, 09:53 PM My 97 with the5.7 acted like that it was the fuel pump. Funny thing happened with pressure test it had 60 p.s.i but when I tried to accelarate fast it would bog down. I changed the fuel pump it ran normal. I was told it had enough pressure but not enough volume. Low-Low-SIERRA 01-07-2007, 11:32 PM So I took my truck to get a diagnos. It gave me EGR sensor and the Air Mass flow. So I replace them and truck is still doing the same. I took it back to the place I did the diagnos and did the diagnos again and it gave 2-4-5-7 pistons are mis firing. The mechanic said to change the distribiator cap wire's and plug and this should make the truck run normal. What do you guys think should I do this? Thanks in Advance. E B 01-08-2007, 08:36 AM Try the lowest cost fix first,my truck would idle fine , but when I tried taking off fast it would stumble. I could get to highway speeds if I eased into it. E B 01-08-2007, 08:53 AM By the way when it was doing all the stumbling it was the fuel pump. Now I just had a problem with misfire at no 4 and the intake gaskets were bad E B 01-08-2007, 08:53 AM By the way when it was doing all the stumbling it was the fuel pump. Now I just had a problem with misfire at no 4 and the intake gaskets were bad maxwedge 01-08-2007, 09:39 AM So I took my truck to get a diagnos. It gave me EGR sensor and the Air Mass flow. So I replace them and truck is still doing the same. I took it back to the place I did the diagnos and did the diagnos again and it gave 2-4-5-7 pistons are mis firing. The mechanic said to change the distribiator cap wire's and plug and this should make the truck run normal. What do you guys think should I do this? Thanks in Advance. Sure let them do this work with a written guarantee that this will fix it, if not you get a refund. E B 01-08-2007, 10:39 AM Good idea make them back their diagnosis Automotive Network, Inc., Copyright ©2012
