Got trans fixed now power steering problem.milehighguy219 01-03-2007, 07:56 PM Ok I recently went and had my transmission fixed. Things are great with the transmission it could not be better. Here is my dilema now my power sterring has gone out. When I took my car to be worked on it was working just fine. Well they told me that they checked it out and didnt see anything wrong with it. I also checked the fluid level and there is no whistlleing sound so I am not sure it is the pump because wouldnt that go in time not all of a sudden?? Anyways I am going to take it back but what might the problem be the belt, could that have pinched a line??? THanks for looking.. Is this something ther transmission shop did to the car?? 2002 Dodge Stratus Automatic Trans 2.7 Litre V6 UncleBob 01-03-2007, 09:51 PM worked fine before they touched the car, didn't work after they touched it I don't even need to look up the details of tranny removal to know the answer to this one. the instructions for tranny R&R I have aren't very clear. It suggests that you may need to remove the entire rack/K member to pull the tranny. But I'm not positive. But either way, sounds like they messed something up. milehighguy219 01-04-2007, 02:48 PM Thanks for the help GreyGoose006 01-05-2007, 08:07 PM is the belt tight? are the lines connected? its probably something simple like that. even if the poser steering belt is tight, there may be a related belt that drives the belt that drives the power steering could be loose. Automotive Network, Inc., Copyright ©2012
