Originally Posted by FRED_C
but do you think cylinder wear would apply even considering the cars runs absolutely perfect during the hot summer months?
Yes. Heat is your best friend when it comes to something like this. The cold tends to shrink the gaskets and seals, also making them stiff and nonconforming if you will. There's enough compression to keep the car going but not enough to make it run smoothly. During the summer, everything is fine because the heat keeps everything loose and tight. Since it's only during the cold you are experiencing this, then this is most certainly a plausable problem.
For instance, my car has a hunt idle on start up now that the winter is upon us. Only when it has sat for a while and cooled down. The intake plenum gasket is cracked somewhere and causing a slight air intake leak that the engine almost can't adjust to quickly enough so the RPM tends to hunt between 400-1000 RPM, sometimes it stalls. Once it's been running for a bit, I can start it up without any hunting. Summer time is fine.
Amazing the problems cold weather can bring out...
