Automotive Forums .com - the leading automotive community online! Visit IgorSushko.com and see what it's like racing in Japan
Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Chevrolet > Astro > M Bodies
Old 01-03-2007, 12:40 PM   #1
cfo
cfo Normal reputation
2000 astro won't downshift
After sitting for 5-6 hrs and then starting up to go somewhere the transmission works perfectly. After 15 minutes or so of stop and go traffic the transmission will bam into 2nd gear from a standstil accelerating. Then It will not downshift to first gear at the next stop. It will start in 3rd and stay in 3rd till you stop and shut off the ignition for 10-20 seconds. Then the trans will run all day perfectly until you shut off the truck for 5-6 or more hours.
A "reputable" trans shop had the truck for 2 weeks and replaced the solienoids and the ignition switch wiring harness as the codes indicated. no luck. An aftermarked security system had been installed when the truck was new and was wired into the ignition switch wiring so they uninstalled the security.. Now i'm out the security and 300 or so bucks and nothing. Can anyone help?
cfo is offline   Reply With Quote
Old 01-05-2007, 10:43 PM   #2
Blue Bowtie
Registered Offender
Blue Bowtie's Avatar
Blue Bowtie Normal reputation
Re: 2000 astro won't downshift
Is there a constant "CHECK ENGINE" light while driving?
Did the trans shop happen to remove the valve body? Inspect the separator plate? Check the accumulator? (A good trans shop should have recognized the symptoms.)
Blue Bowtie is offline   Reply With Quote
Old 01-07-2007, 11:58 AM   #3
cfo
Thank you for coming back to me. The engine light stays on and has since this situation started. Did they what? The trans shop and the Chev dealer both said they checked everything.. duh I know what that means as the prob stil exists.. they did'nt check something or they could have fixed it. My prob and the rest of the "Publics" prob is we don't know what to ask. You mentioned the plate and the valve body.. do you know what to look for in the valve body specificaly to this prob and what do I look for in the plate? Your appreciated in advance for helping me.. thanks
Old 01-09-2007, 10:12 PM   #4
Blue Bowtie
Registered Offender
Time to find another reputable shop. And not all dealershsips have transsmission-trained technicians, even though they might try working on one anyway.
Bookmarks
Google
Web AF
