88 Cherokee will not stay startedjeeper186 01-02-2007, 12:46 PM Ok guys, I feeling pretty stupid here. But here it goes. I have a 1988 Jeep Cherokee 4.0L Has intermittent starting trouble. when cranking, it will start then die. I have connected a wire from the battery that goes to the starter Relay/Solonoid that is located on the fender well behind the battery on position "F". This keeps the Jeep running. The fuel pump then runs constantly but the Jeep does not die on me. I have to keep the wire on the Relay/Solonoid. What could this be? Please help :banghead: 89ltd 01-05-2007, 08:49 AM that sounds like the B+ latch relay under the hood, also know on later models as the auto shut down relay, if you keep the key in the start posistion,, will it keep running? jeeper186 01-05-2007, 10:43 PM Yes it does. Thanks, I have changed out the relay. Maybe a bad wire to the relay? Automotive Network, Inc., Copyright ©2012
