Water KillsjustJEEPit 12-30-2006, 08:57 PM I have a 1987 cherokee pioneer and i have a problem with it dieing in water, well when water tuoches the engine. Ive check my distributer and its not cracked and i was thinking mabye the alternator shorts out when water hits it. And it wont start up for at least five minutes som times longer and also I took it threw my buddies pond and it died instantly and would not start but once they pulled me out far enough out that my engine was out of the water it started right up. And also i was wondering if S10 leaf springs will fit under my jeep with out modification. fredjacksonsan 12-30-2006, 09:11 PM It sounds like you're getting something shorted out. How deep is the water? Try this: http://www.automotiveforums.com/vbulletin/showthread.php?t=175868 justJEEPit 12-30-2006, 09:22 PM Bumper Deep (stock height with 31s) and most of the time splash up fredjacksonsan 12-30-2006, 09:26 PM I'm thinking something is shorting out. Probably a good idea to check all the wiring that would be exposed at that depth, and also have a read of the thread I posted earlier. justJEEPit 12-30-2006, 10:02 PM Could it also be a bad alternator? it does skweek often. fredjacksonsan 12-30-2006, 10:06 PM I don't know....does that water level cover up the alternator? A squeaking alternator (if it's the belt) indicates that there is slippage....you might replace the belt if it's worn, and check the tensioner. 4x4grey88 01-02-2007, 11:58 PM I have a 1987 cherokee pioneer and i have a problem with it dieing in water, well when water tuoches the engine. Ive check my distributer and its not cracked and i was thinking mabye the alternator shorts out when water hits it. And it wont start up for at least five minutes som times longer and also I took it threw my buddies pond and it died instantly and would not start but once they pulled me out far enough out that my engine was out of the water it started right up. And also i was wondering if S10 leaf springs will fit under my jeep with out modification. There are many things that could be shorting out while you drive you Jeep in the WATER. Try this.. Get a garden hose at your house and spray water under the vehicle while it is running (trying to simulate deep water) and see where your spraying when the engine turns off. Yes... Spray everything that you might thing will be getting wet (o2 sensor, alternator, wiring, everything). This should give you a direction on what to have fixed. Dodge Dakota leaf springs will work under your Jeep, check this link out: http:www.lunghd.com and click on 'budget lift' or http://www.lunghd.com/Tech_Articles/Suspension_Steering_Axles_and_Brakes/Budget_Lift.htm Keep Us posted. justJEEPit 01-08-2007, 06:56 PM hey thanks thats a great lift plan. I am definatly going for it. Also do u know of any comon places the a jeep leaks small amounts of oil. Automotive Network, Inc., Copyright ©2012
