Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Chevrolet > Astro > M Bodies
Old 12-30-2006, 06:15 PM   #1
Robertofo
Robertofo Normal reputation
Astro Van 97 water filtration from rear door and window Please healp...
Astro van 97 water filtration for the rear cargo doors- PLEASE HELP!
i am unable to stop this pls let me know wher I can find the gaskets for this doors .......... PLEASE HELP.....
Robertofo
from Guatemala
Robertofo is offline   Reply With Quote
Old 12-31-2006, 04:00 AM   #2
94&92Astro
94&92Astro Normal reputation
Re: Astro Van 97 water filtration from rear door and window Please healp...
Robertofo
from Guatemala
I had the same problem on my 97 (I own 4 now 92,94,97,02) As it turned out water was actually entering from the rear stop light on the top of the van. Water runs back on the roof channels with alot of force while driving and will create leaks over time. I removed the screws securing the light, then cleaned all the crud underneath with some acetone and a soft wire brush. There is a plastic gasket there so either remove it or clean top and bottom of it. (rust must be removed and treated)Then get some aqarium grade sealant applied to all surfaces and reinstall.(a small bead all the way around after securing too) Make sure everything is dry and give it a full day before getting wet. I hope this helps.
94&92Astro is offline   Reply With Quote
Old 12-31-2006, 06:04 PM   #3
Robertofo
Thank for your mail, I will Try it, Pls let know if you know wher I can buy the gaskets of the back door tru internet, and pls let know your comments about the astro van, I resently by it model 97.
Regards,
Robertofo
Old 03-31-2008, 11:44 PM   #4
George Wood
George Wood Normal reputation
We also had this problem on our '90 and '99 vans. On the '99, the left door striker plate, (loop on the floor that is the catch for the door) is through bolted to a plate on the under side of the floor. This plate can be adjusted inward to tighten the seal od the door gaskets of both doors. This is done by loosening both bolts and sliding the strike toward the front of the car.Do not remove both of these bolts as the screw plate underneath will drop out of sight. If you cannot get enough adjustment elongating the holes in the sheet metal of the floor will give you more adjustment. To do this first remove 1 of the two bolts that hold the loop in place and loosen the other but do not remove it. Elongate the one hole, replace the bolt then elongate the other hole. Seal the bolt holes w/ clear silicone caulk.
George Wood is offline   Reply With Quote
Old 04-01-2008, 08:34 AM   #5
Leeann94astro
Leeann94astro Normal reputation
^ You do realize you're answering old - more than year-old - threads, don't you?
Leeann94astro is offline   Reply With Quote
Bookmarks
Google
Web AF
