map senso issues
wjaso
12-30-2006, 12:27 PM
1989 Wagoneer Ltd,4.0 L Can a map sensor cause intermittent start issues,recently have had a crank but no start condition on occasion and it seems that if I disconnect the map sensor and then reconnect it,it will run and have no problems for days and then same thing,any insight would be appreciated.Thanks
Stick89
01-03-2007, 05:17 AM
There should be a short piece of hose going to the MAP....replace the hose first....mine was cracked and I replaced just the hose....As a matter of fact check ALL your vacumn hoses.....Check on the passenger side behind the fron bumper....there should be a vacumn cannister.....Vacumn leaks can cause a few problems....but are fairly easy and cheap to fix.....
citizen@large
01-03-2007, 10:14 PM
I also had the same exact thing happen to my '89 4.0L... It took a few days to diagnose, but once I found that it was the wiring there at the MAP, I just cleaned the contacts as best I could w/a little sand paper, then applied some dielectric grease and squished it back together. Not another problem since... 4 mos ago...
