97 Sunfire skipping need help
Google
Web AF
jer one
12-28-2006, 12:05 PM
:uhoh:
Hi All, I have a 1997 Pontiac Sunfire, last month I drove it about 58 miles put it in the garage and it was running fine, two weeks later I started it up to move it and it was skipping and the check engine light was on. I installed new spark plugs to no avail, so I took it to Advance Auto Parts and they put it on a scanner and it shows the following; Vehicle scanned Global OBDII vechicle, DTC (Codes), P0200 Injecter Circut Open,, P0302 Cylinder 2 Misfire Detected, any ideas where to start on this problem?? I appreciate any help on this, thanks, Jerry.
i3o2Matt
12-30-2006, 02:23 AM
cylinder 2 injector...test it to see if it is working properly.
jer one
12-30-2006, 01:07 PM
:smokin:
Thanks Matt, now all I have to do is figure out how to do that, thanks, Jerry
i3o2Matt
12-30-2006, 03:12 PM
i dont remember exactly how, otherwise i'd tell you...
sbaker1
02-01-2007, 02:01 AM
My car did the same exact thing twice. The first time I replaced the coils, that worked. It did it again and I had to replace the ignition coil cover. The coil covers go out quite frequently on my car. I was also told # 2 injector that wasnt it. We finally figured this out after lots of $ later
bmac8jr
02-11-2007, 12:20 PM
My car did the same exact thing twice. The first time I replaced the coils, that worked. It did it again and I had to replace the ignition coil cover. The coil covers go out quite frequently on my car. I was also told # 2 injector that wasnt it. We finally figured this out after lots of $ later what was wrong ? My cavilier has the same codes and I replaced the coil, modual, knock sensor, crank sensor, cam sensor, injectors ?
bmac8jr
02-11-2007, 12:23 PM
what was the problem ?
Google
Web AF
