2002 trailblazer headlightsbutch62255 12-27-2006, 08:27 PM :confused: how the heck do you get to the drivers side headlight bulb to change it? lookes like you gotta remove a lot of stuff? maxwedge 12-27-2006, 10:25 PM Reach in behind the lamp between the battery and the back of the h'lite, there is a black rubber cover on the opening to the bulb, pop it off and turn the the bulb out of the receptacle. butch62255 12-28-2006, 08:01 PM thank you very much for your help......happy new year to ya! rodeo02 12-29-2006, 07:57 PM I'm pretty sure there's release clips/rods that pull straight up and out from the rear of the lense assemblies which allows the whole lense assembly to fall right out (most GM's and fords are like this). From there you twist and pull the lamp holder out and replace the lamp. Joel maxwedge 12-29-2006, 08:06 PM I'm pretty sure there's release clips/rods that pull straight up and out from the rear of the lense assemblies which allows the whole lense assembly to fall right out (most GM's and fords are like this). From there you twist and pull the lamp holder out and replace the lamp. Joel Joel, the TB is not set up this way, the lamps fit behind the grille extensions, lots of people unecessarily remove the grill then pull the lamps, I can get my oversize stiff old hand back there as I described on the lt one, rt one requires removing the air filter housing. Automotive Network, Inc., Copyright ©2012
