Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Chevrolet > Tracker
Old 12-27-2006, 04:10 PM   #1
Shogunslinger
Shogunslinger Normal reputation
4WD Indicator light not working
When I put the Tracker in four wheel drive the green 4WD light at the top of the gauges doesn't come on. I know it is no big deal, but I am worried that there is something wrong with the electrical system. Thanks.
Shogunslinger is offline   Reply With Quote
Old 01-24-2007, 12:58 PM   #2
scoobytuff
scoobytuff Normal reputation
Re: 4WD Indicator light not working
Check and see if there is a sensor on the transfer case. If so that could be your problem.
scoobytuff is offline   Reply With Quote
Old 06-19-2007, 10:44 AM   #3
trackerfixxer
trackerfixxer Normal reputation
Same thing happened to me. It is easy to trouble shoot but the a new 4wd air pump is around 400.00 bucks or more. 1st find the pump. its located just behind the front bumper just right of center it has a small wire harness and 2 black air tubes connected to it. disconnect the harness then start the car if the light is on then the pump is bad and i can help. do not buya new one because GM charges too much. I also thought it was just a indication problem but it was not. if it can shift in andout no problem wrong when you shift in to 4 hi or lo there is an air pump that comes on to engage the front axle if that does not happen you are not in 4wd all that happened was you are sending torque foward to the front axle and you can feel a slight differance in how it drives but like i stated the front end is not engaged. the light will not come on untill the pump has come on and built up pressure to turn the light on with a pressure switch in the pump.
trackerfixxer jpgulbrandson@yahoo.com
trackerfixxer is offline   Reply With Quote
Old 06-24-2007, 10:44 AM   #4
augie7071
augie7071 Normal reputation
I had same problem on my "03". I messed with the connectors, unplug and replugged, between the engine and firewall. I don't know what i did but it works now.
augie7071 is offline   Reply With Quote
Old 07-27-2007, 12:28 PM   #5
Shogunslinger
Thanks for the info, i am going out right now to mess with it.
Bookmarks
Google
Web AF
