95 Grand Am cooling fan runs constantly
cook28
12-26-2006, 08:19 PM
I have a 95 Grand Am with a 2.3 DOHC. Upon starting the car the cooling fan immediately starts. The check engine light went on around the same time this started. I reviewed the schematic for electrical connections and was unable to locate a relay that may be the cause. I have never heard of this and I'm not sure if the check engine light has anything to do with the problem. I'm lost on this one.
xeroinfinity
12-27-2006, 05:43 PM
Welcome to AF !
I'd say you have a relay bad making the fan run.
Pass,side under the hood are 4 relays.
2 are the same, 1 is AC the other is the fuel pump.
One of the other two is for the fan.
Cant really say which one it is because these get moved around. But it would be easy to find out, just by unplugging them one at a time to see which one kills the fan.
Most part stores can test them too.
MT-2500
12-27-2006, 05:56 PM
Also find out what the code is with the check engine light.
Some times a problem in pcm will command fan on.
cook28
12-28-2006, 01:46 PM
MT thanks I'll give that a try and see what happens.
