Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Ford > F Series
Old 12-25-2006, 07:41 AM   #1
rameam
rameam Normal reputation
91 4.9l doesn't want to fire when cold?
I've been having trouble with this for quite some time. When I first bought it (used in 98), every once in a while it would not start. I discovered if I turned the key on for a few seconds, turned it off, then back on - doing this several times, it would start (though I'm inclined to believe now that only the key on time was helping). Over a period of time it got worse. I would have to hook a battery charger/booster to it and crank and crank and crank. Finally it would start.
Replaced the fuel pump (which I really thought was the culprit), filter, and pressure regulator. Replaced plugs, wires, rotor, dist cap, and coil. Put a new battery on it the other day. I discovered that if it doesn't start, just leave the key on for sometimes a minute, sometimes several minutes, then it will start like nothing was ever wrong.
It seems to have something to do with the cold start mechanism (I think), but I don't know what kind of mechanism it uses, or where it's located. Anyone with any advice or info please sound off. I'll listen to anything.
rameam is offline   Reply With Quote
Old 12-26-2006, 07:45 AM   #2
dstrick32
dstrick32 Normal reputation
Re: 91 4.9l doesn't want to fire when cold?
Sounds as if you might have a fuel pressure leak down problem. It could possibly be a bad injector or more.
92 Chevrolet Silverado 5.7 Automatic 2X4
dstrick32 is offline   Reply With Quote
Bookmarks
Google
Web AF
