Our Community is 940,000 Strong. Join Us.
How to lower the Integra......simple......just take a look at it.....
AccordTypeR
09-21-2002, 09:27 AM
Wassup People?
This post is for the people who don't have any idea that make a car low
down......here is one example with Integra.....just cut the places that
i've marked in color.....but notice that if you lower about 1mm at the
rear suspension you should cut whole 1mm from ony suspension....and
you can cut 0.5mm at the front each from body and suspension....and
the struts.....you have to cut it 1mm....(my Eng. SUX:D )
anyway......i hope it helps for everyone.....:D THX
AccordTypeR
09-21-2002, 09:28 AM
rear suspensions......
AccordTypeR
09-21-2002, 09:31 AM
struts.......remember that you cut these 1mm
Veyron
09-21-2002, 09:39 AM
When I lowered my FTO, I just cut away the top 2 or 3 coils off leaving the center post, which lets the strut sink deeper into the mounting hole. This way you can lower it little by little til you get the hight you want, then adjust the rest of the suspension accordingly.
ZoomZoomMX-5
09-21-2002, 09:57 AM
If you cut coils off the top, it's easy to drill the top of the coil spring/strut area and replace the locating pin w/a piece of styrene rod or brass, or leave it off so that you can "glue tweak" the final assembly so the wheels fit the wheelwells and sit perfectly level.
*Cru_Thik*
09-21-2002, 11:08 AM
this is what i was looking for, thanx so much *AccordTypeR* :D ....now back to my project.
turbos86
09-21-2002, 04:31 PM
pkw1 wrote a thread excatly the same a few months ago, even with the pictures showing excatly the same cutting locations.....:rolleyes:
*Cru_Thik*
09-21-2002, 04:50 PM
well i didn't hurt to see it again....didn't it ;)
InTeGrAbOy18
09-21-2002, 04:54 PM
where was this post last week
damn hahaha finish my type r too i lowered it but did a shitty job
AccordTypeR
09-21-2002, 08:42 PM
I didn't even know that he posted or not.....I never copied anyones though......
