Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Nissan > Skyline / Skyline GT-R > Performance
Performance Discussion about performance modifications and issues.
Old 12-23-2006, 11:50 PM   #1
GTSGOD
GTSGOD Normal reputation
please help! overboosting problem
hi pplz
thanks so far for your intel, i have another problem... ive tuned my car with the pfc and ebc but it was tuned on a hot day.. i took it out last night on a cold day, nailed it and there was boost spiking.. is this because ive tuned it on a hot day and the air is thicker? i turned the boost down and and its holding boost properly now. should i have another setting on my ebc for a hot day too?
hot day went to 13psi no probs, then on the cold day went to 14.7psi.. turned it down for the cold day and made 13psi again... im confused... sorry bout all this chit chat.
thanks guys
GTSGOD is offline   Reply With Quote
Old 12-24-2006, 05:20 AM   #2
SkylineUSA
SkylineUSA's Avatar
SkylineUSA Normal reputation
Send a message via AIM to SkylineUSA
Re: please help! overboosting problem
Originally Posted by GTSGOD
hi pplz
thanks guys
Dense air could make it spike, because you actually have more volume at the same psi, which will make the turbo spin a little quicker, how much? Not sure.
As for EBC, just change it for what you need.
R32 GTR w/351w .020 forged, 8.9:1, PTK T76, Turbosmart 40 BC & 45 WG, Tial 40 BV, AFR 205s 310/245, 228/228 550/550 114 Hydro, 1.7rr, Isky RLs, 4" HKS exhaust, ARC 30x16x4 IC, 8 point cage, C2 gauges, 2 step, C4 3200 stall w/ R Manual & Hurst Ratchet shifter, 17" Panasport G7s, CSU 750 & bonnet, Vic Jr intake, 3.63 gears, Corbeau Carrera seats, Custom wide body, Bomex side skirts and rear 1/4 caps, Tommy Kaira bumper.
SkylineUSA is offline   Reply With Quote
Old 12-25-2006, 01:06 AM   #3
GTSGOD
should i lower the spool up rate on my ebc?... ive turned it up abit
Old 12-25-2006, 01:16 AM   #4
SkylineUSA
SkylineUSA's Avatar
As long as it does not over boost, your golden.
Old 12-28-2006, 12:18 AM   #5
EDTHEMANJP
EDTHEMANJP Normal reputation
It is normal for the boost to be higher when the weather is colder, denser air. Yes you need to monitor and change your boost settings for different weather conditions.
Moisture is going to affect it to as is dryer air.
EDTHEMANJP is offline   Reply With Quote
Old 01-03-2007, 07:29 AM   #6
GTSGOD
so therefore it feels like im getting more power cause it actually goes better in colder weather. my front bar is upgraded and my cooler sits behind an opening and u can see the cooler. would this help and how much power increase would this do considering i explained this front bar scenario? Also im curious how much 730nm of torque is atw to the flywheel.. does anyone know the precise calcs
thanks guys
Old 01-05-2007, 04:34 AM   #7
mmcleo11
mmcleo11's Avatar
mmcleo11 Normal reputation
I answered your torque question HERE
Post up the dyno graph and I can tell you exactly how much torque you have at the flywheel. If you cannot post, catch me on MSN
N14 Pulsar
VQ35 conversion with major N/A upgrades, 6 spd FWD manual HLSD
18" Rims, big brake kit, Coil overs and freshly painted
Smashed Black VY SS Ute
The workhorse...
Twin turbo 5.7L LS1
Boyd Coddington 19" Turbine Wheels
AP Racing 4 Piston Brakes
Tein Coil over Suspension
HKS EVC 6 Boost Controller
PLX Devices DM-200 OBDII
Custom Front Mount Intercooler
mmcleo11 is offline   Reply With Quote
Old 01-05-2007, 04:38 AM   #8
GTSGOD
whats your msn mate? private message it to me if u can
cheers
Old 01-05-2007, 08:36 AM   #9
RazorGTR
Skyline Man
RazorGTR's Avatar
RazorGTR +350RazorGTR +350RazorGTR +350RazorGTR +350
Another thing to keep in mine about temp changes. If you tune your car on a hot day, then later in the year when cool weather moves in you're AF ratio will also go out of wack. You could be running up to 3 pts leaner due to the air density difference. If you have a way to check that I would. This to me would also be a great consern, especially if you wind up +12 to 1 AF.
1.5 psi difference on boost shouldn't make you worried unless you've tuned your car to the edge on the hot day. 3psi would definately concern me though.
You don't own a Skyline, then don't cry to me about it!
1992 Silver R32 GTR tickled to 450hp. - Sold when I left NZ in 2004
Arguing on the Internet is like competing in the special olympics. Even if you win, you're still retarded.
Never confuse kindess with weakness.
AF user guidelines, Please remember to abide by them
RazorGTR is offline   Reply With Quote
Bookmarks
Google
Web AF
