Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Chevrolet > Avalanche/C&K/Silverado/Suburban/Tahoe > Tahoe
Old 12-22-2006, 09:14 PM   #1
djkurious
djkurious Normal reputation
removing ignition switch
How do you remove the ignition switch cover. There are 2 covers. I have removed the bottom one and cant get the top cover around the keyhole. See pic.
djkurious is offline   Reply With Quote
Old 12-23-2006, 06:39 AM   #2
GMMerlin
I know stuff
GMMerlin's Avatar
GMMerlin Normal reputation
Re: removing ignition switch
You have to turn the ignition switch to the start position and depress the pin on the top with a 90 degree pick.
When the switch comes out, you can remove the cover
Why do you never have enough time or money to do the job right the first time, but enough time and money to do it again?
Got all the certifications
25 years ASE Certified Master Technician
GM WCT
Yea..I work at a DEALERSHIP....got a problem with that?
Want to diagnose cars like the Pros? FOR SALE: OTC Perception 2 channel Labscope (badged as a Matco Reality)
This is my personal labscope that I use to diagnose waveforms, like new, comes with leads and training video
PM Me for details
GMMerlin is offline   Reply With Quote
Old 12-23-2006, 10:11 AM   #3
Scrapper
Scrapper Normal reputation
Smile Re: removing ignition switch
he's rite and good picture of it to...i bet white wire broke but to you guy thanks for the good picture of it....i couldn't have done it better myself..lol..
SCRAPPER....
Scrapper is offline   Reply With Quote
Old 12-23-2006, 10:15 AM   #4
Scrapper
Oh Yah Merry Christmas And Happy New Year To All In This Forum...
Old 12-23-2006, 11:46 AM   #5
djkurious
Hey thanks guys. I got frustrated this morning and brought it to my local chevy dealership and they say its something busted in my transmission and I need to replace the transmission--$3000. I'm taking the truck back home and changing this ignition switch! Also, what is the "pin on the top?"
Old 12-23-2006, 12:40 PM   #6
Scrapper
Exclamation Re: removing ignition switch
they might be talking about a GV pin its inside the bottom of tranny pan...
Old 12-23-2006, 12:42 PM   #7
Scrapper
they might be talking about a GV pin its inside the bottom of tranny pan and pin in bottom of tranny.what happens is they get sheared..good luck.
Old 12-23-2006, 01:05 PM   #8
GMMerlin
I know stuff
GMMerlin's Avatar
What is wrong with your vehicle.
Why are you replacing the ignition switch?
GM WCT
PM Me for details
Old 12-23-2006, 01:42 PM   #9
djkurious
The service engine light came on and I didn't have any reverse, Wouldn't go into 4th gear (overdrive), and in 1st gear, and it would rev up to 3500 rpm's before shifting to 2nd gear.
I took it to AutoZone to get the codes read:
P0740 - TCC enable solenoid circuit electric
P0785 - 3 - 2 shift solenoid circuit electrical
P1860 - TCC PMW Solenoid circuit electrical
I did some research on this wonderful website and saw that I was not the only one with this problem.
Old 12-23-2006, 01:53 PM   #10
djkurious
I am confused to what the pin on top is? Can you further explain?
I looked for a pin and still no luck.
99 Tahoe LT
Old 12-23-2006, 08:00 PM   #11
GMMerlin
I know stuff
GMMerlin's Avatar
OK sounds like 2 problems.
First off, your trans isn't shift to 2nd, it is probally going into 3rd.
No reverse, 2nd or 3rd gear is the result of a broken reaction sun shell.
Typically this is not an overhaul job. With a quick pan inspection for metal, you can usually go in and replace the sun shell and call it good.
I have done this many times with no other trans problems..usually a couple hundred dollar repair....many trans guys hate me for telling you this because they want the O/H price, but not entirely necessary.
Secondly, the codes could be a result of the igniton switch, but I would check fuses first.
The pin for the ignition switch is found in a hole on the top of the column under the plastic, you will have to tilt the left side of the upper cover up and reach in there with the pick to deprss the button in the hole to release the cylinder.
GM WCT
PM Me for details
Old 12-26-2006, 12:05 PM   #12
djkurious
Hey thanks for the info. I will see if I can find a place to just replace the sun shell. how much do you think that price will be? Chevrolet wants 2800.00 to just replace the sun shell and the labor was 17 hours. Is this ridiculous? to replace the entire transmission was 3000.00. The sun shell price was only 48 bucks. Will transmission shops just replace the sun shell?
Old 12-27-2006, 10:40 AM   #13
Scrapper
yes that's the going rate on tranys 2500 to 3000...sorry and good luck.....
SCRAPPER...
Old 12-27-2006, 11:19 AM   #14
Blue Bowtie
Registered Offender
Blue Bowtie's Avatar
Blue Bowtie Normal reputation
How did we get from an ignition switch problem to a transmission overhaul?
If you open the transmission without inspecting the rest of the components, you may be sorry later.
The problem is common enough that the last time I did one I tried to document it as much as possible. If you want an idea of what's involved, check this link:
4L60 Repairs
Blue Bowtie is offline   Reply With Quote
Old 12-28-2006, 12:04 AM   #15
djkurious
This is the problem I am having. I really think that if GM is making a weak component, they should replace it free-of-charge. I love my tahoe, but this is making me not wanting to by a GM vehicle again!
By the way, nice write-up about the transmission. Kudos!
Bookmarks
Google
Web AF
