Driver Side Window Problems87BoxClassic 12-21-2006, 06:32 PM Does anyone know how to change that band that goes around the gear thing inside the door because my window goes up and down about 2 inches :banghead: . i think it's called a regulator, it's a discontinued part so i gotta hit the junkyard up. So any help removing it and putting it back on will help thanks silicon212 12-21-2006, 07:13 PM Actually, the band is called regulator tape - it's a part of the regulator. You can get regulator tape for this at Autozone in the Help section - it's like $17 or so. 87BoxClassic 12-22-2006, 05:36 PM How do i remove the regulator? do i have to drill out those pop rivets? then when i get it, if it's not obvious how do i replace the tape? 87BoxClassic 12-23-2006, 04:12 PM well i'm gonna go on a mission of replacing the regulator anyone got any tips? 87BoxClassic 01-03-2007, 05:37 AM i finally replaced it, it's not hard just drilled out the 5 pop rivits holding it in and replaced with bolts works like a charm now bobss396 01-03-2007, 09:27 AM Good going, we all learned something, glad it worked for you. Bob Automotive Network, Inc., Copyright ©2012
