Wiring Schematics for 99 Grand AM GT
lil754boy
12-21-2006, 12:56 AM
Dashboard lights are not working on my 99 GT. Checked the fuse box on the passenger side of car and the fuse us not blown but powers not getting to fuse. Dash/radio/speedo/gas/rpm/light/ does not work due to this failure. Please assist!
xeroinfinity
12-21-2006, 09:25 AM
Have you been experiancing any other syptoms ?
Thier is also a fuse in the driverside fuse box, IPC/BFC ACC , and the IPC/HVAC BATT.
This is not a typical problem with the 99's.
Though I have seen and heard of a couple that went out after installing gauge faces,
or just from removing the dash cluster and not installing it correctly.
Hope that helps!
lil754boy
12-22-2006, 01:08 AM
I chechek both fuses. Both were fine! This thing is driving me to drink.
xeroinfinity
12-22-2006, 09:10 AM
Thier may be more then those two fuses.
But I'd also check you dimmer switch on the dash.
If this is malfunctioning you will have no interior lighting.
Here is that wire diagram for the instrumnet panel.
interior lighting/instrumnet panel (http://i28.photobucket.com/albums/c242/xeroinfinity/SeCond%20Hand/interiorWireDiag.jpg)
Hope that helps.
