Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Honda > Civic > '92-'95 Civic/EL/Civic Hybrid/Civic GX NGV
Old 12-20-2006, 06:04 AM   #1
hany
hany's Avatar
hany Normal reputation
timming belt cut
i need to know what will happen if the timing belt get cut during the car walk ?
MY ENGLISH IS NOT PERFECT. sorry for that
1992 CIVIC 4DOOR ULTRA BLUE TURBO -SOLD
1996 CIVIC 4DOOR EUROPIAN VTEC LS
2003 CIVIC LXI
1999 GOLF 4 1400 CC
hany is offline   Reply With Quote
Old 12-20-2006, 09:10 AM   #2
jhong1226
jhong1226's Avatar
jhong1226 Normal reputation
Re: timming belt cut
walk???
jhong1226 is offline   Reply With Quote
Old 12-20-2006, 09:12 AM   #3
jhong1226
jhong1226's Avatar
if you mean when its running, you might have damage either the piston or valves when the belt broke. you might as well swap the engine in this case.
Old 12-20-2006, 05:30 PM   #4
hany
hany's Avatar
sorry for using walk but i mean running,
i asked that question beacuse i have a golf 4 and the timming belt get cut and i had to change all the valves .
and yesterday i heard someone say in the honda engines when the timming belt cut the engine will cut without any damage at the valves . is that right ?
2003 CIVIC LXI
1999 GOLF 4 1400 CC
Old 12-20-2006, 05:40 PM   #5
maxassassin
maxassassin's Avatar
maxassassin Normal reputation
Send a message via AIM to maxassassin Send a message via MSN to maxassassin
im pretty sure msot hodna engines are no interferances engiens meaning if your timing belt snaps or breaks or whatever while running you jsut gotta ptu a new one on and re time it. no damage what so ever.
AF PRIMER CREW
06 cbr 600 f4i
75 ford f150-mega parts cruiser.
91 civic hatchback.
96 nissan pathfinder
maxassassin is offline   Reply With Quote
Old 12-20-2006, 06:07 PM   #6
hany
hany's Avatar
yes i get it now thanks alot
2003 CIVIC LXI
1999 GOLF 4 1400 CC
Old 12-21-2006, 02:41 PM   #7
CivicSpoon
CivicSpoon's Avatar
CivicSpoon Normal reputation
Honda engines (at least for the most part, I don't know if all of them are), are infact interference engines. Some people can just replace the t-belt and drive it, while others have to replace valves (or worse). It's just the luck of the draw, and how long they continued to run the engine after the t-belt took a crap.
CivicSpoon is offline   Reply With Quote
Old 12-21-2006, 06:01 PM   #8
hany
hany's Avatar
yes i get it now. that mean if the engine stoped during running without any expected reason the one must not try to start the engine again and have to check the timming belt, thanks alot CIVICSPOON
2003 CIVIC LXI
1999 GOLF 4 1400 CC
Old 12-21-2006, 07:24 PM   #9
CivicSpoon
CivicSpoon's Avatar
Well, not really. In most cases like the example you gave, it'd be more likely that it's something else than a t-belt snapping. I've owned 2 cars (my '94 CX and an oldsmobile), and both have had problems in the past where they would just shut off on their own. All those times the problems were that the cars weren't getting spark, neither snapped a t-belt ever. The best way to make sure that a t-belt doesn't snap is to check it periodically. Even if you do it when you're changing your oil, that should be soon enough to find out if there's a problem. Check it for obvious wear and cracking. And if it's worn or cracked, don't drive it (not even to go buy another t-belt).
Old 12-22-2006, 05:29 AM   #10
hany
hany's Avatar
sure that is better if you check it periodically. but as i know the t-belt must change every 70 000 km . so you can start to check periodically at 50 000km.
2003 CIVIC LXI
1999 GOLF 4 1400 CC
Bookmarks
Google
Web AF
