94 EX axle nutTireburner 09-20-2002, 02:50 PM Does anyone know what size the right front axle nut is for a: 94 Civic ex 1.5L Canadian mfg. Thanks!! sparq 09-20-2002, 04:16 PM 32mm Tireburner 09-24-2002, 08:49 AM Thanks Sparq! Couple more questions, 1) Is there a secret to getting the axle out of the cv joint? The directions show it should just be a cir-clip (2) holding it in. Thus with enough pressure the axle should just pop out. Any hints/ secrets? 2) What method are you using to hold the cv clips into place? drift punch? 3) Is the axle held into the transaxle by circlips also, thus just popping out with enough pressure? 4) Torque spec on that axle nut. Thanks in advance!! Tireburner 09-25-2002, 08:20 AM never mind. I got the job done. Thanks! Automotive Network, Inc., Copyright ©2012
