type-r swap
01_Celica_GT
12-16-2006, 03:21 AM
the Type R engine have 5 bolt axle/hub right? So if I swapped it into my civic then would i need 5 bolt rear brakes too? If i did need 5 bolt back brakes would stock Type R brakes fit on?
hondacivic99sivtec
12-16-2006, 04:24 PM
you don't need the five lug conversion. my friend has a type r swap and he still has 4 lugs. yes the type r brakes would fit all the way around. goodluck.
01_Celica_GT
12-18-2006, 11:18 AM
well doesnt the engine come with 5 lugs? wouldn't i need to convert it to a 4 lug then?
hondacivic99sivtec
12-18-2006, 02:04 PM
only if you buy it with the hubs
sageuvagony
12-18-2006, 09:59 PM
Hubs have absolutely nothing to do with an engine swap. Its almost like saying you have to swap out your front seats to make the engine swap work. :bloated:
01_Celica_GT
12-19-2006, 09:33 AM
oh so i can put the axels into my stock hubs? what was the reasont for acura putting a 5 bolt pattern on the type r anyways?
hondacivic99sivtec
12-21-2006, 08:03 PM
dunno
Pavlo
12-25-2006, 01:48 PM
You just need to use 4 lug B-series axles. The 5 lug spindles also require type-r axles (36mm, compared to I think 34mm on a 4 lugger). And not all of the type-Rs came with 5 lug, JDM pre '96 itr had 4x114.3 lug pattern.
When it comes to brakes, the itr fronts will fit on your EX (you need the bracket, caliper, and lines). For the rears you need the whole trailing arms, or the brakes with the backing plate, e-brake cables, and brake lines.
Good luck with the project.
01_Celica_GT
12-25-2006, 01:58 PM
is it easy to swap my back stock drums to rear disc?
Pavlo
12-25-2006, 02:19 PM
It's not super hard but not easy either. Easiest way is to buy 94+ Integra rear trailing arms, along with the e-brake cables, and brake lines. Then you unbolt the whole trailing arm, take the exhaust off (to run the e-brake cables), and put the new parts on. Then you just bleed the brakes and thats it.
To have the most braking power you'll also need (easiest upgrade) GS-R fronts, bigger master cylinder ('93 EX sedan had 15/16" which bolts in, the GS-R mc will need the GS-R brake booster), and a 40//40 proportioning valve, as without it you probably won't even feel a difference.
Just to let you know, good brake pads, rotors, and lines is the cheapest way to upgrade the braking power, and is very effective.
01_Celica_GT
12-26-2006, 03:57 AM
so for the front what do i need? I need control/trailing arms too or what?
hondacivic99sivtec
12-26-2006, 03:06 PM
why would you want five lug in front and four lug in the rear?
Pavlo
12-26-2006, 04:07 PM
For the front in the EX, all you need is the brake caliper, caliper bracket, and brake lines, thats if you are doing a GS-R upgrade, if you are going for the Legend, ITR or NSX brakes (anything along those lines), then you'll also need the rotors, which will have to be redrilled to fit the 4 lug.
01_Celica_GT
12-27-2006, 08:37 AM
oh no i dont want 5 in the front and 4 in the back. i was curious to how i could swap the b18c5 in without having to do that. i dont want to do that.
But the gsr is 4 bolt and i heard about people putting gsr rear brake conversion in the back of a civic. so i could do that in both the front and in the back?
droopyli05
09-09-2007, 07:50 PM
i have a 1990 integra im trying to do a type r 5 lug conversion just to be different and stand out i found this link some what helpful, but its for a civic
http://hybridautomotive.com/tech/5lug/
though this link might help a few of you guys but im wondering does anyone know if this would be just as easy to do for DA integra please let me know what you guys think
droopyli05
09-09-2007, 07:54 PM
after i do my conversion i plan to get a big brake rotor calipers etc the works as well as a steel brake line ill be broke for a while but i think ill love driving my 300 hp b16a (xsi) with a 5 lug type r suspension swap.
hondacivic99sivtec
09-09-2007, 11:10 PM
don't bring back dead threads. make a new one!
