Automotive Forums .com - the leading automotive community online! Visit IgorSushko.com and see what it's like racing in Japan
Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Pontiac > Grand Prix
Old 12-15-2006, 02:03 PM   #1
boose00
boose00 Normal reputation
Dex-cool causing problems?
Hello I have a 2000 gtp with 80k miles on it and have a check engine light on. The code is p0128 which says that the temp of my car isnt being regulated correctly. The guy at murrays told me to get a flush cause my coolant looks watery. Is he on the right track?
Also I want ONLY THE BEST for my gtp and am in fear of dex-cool. After reasearching i found numbers of problems with it. I already replaced the intake manifold gasket which could of been the dex-cool eating it. I dont want anymore problems like this. I read about Peak Global Extended Life Antifreeze and Coolant. Should i go with this? Is their any other alternative that would be better?
Thank you!
boose00 is offline   Reply With Quote
Old 12-15-2006, 03:32 PM   #2
maxwedge
A990 racer
maxwedge Normal reputation
Re: Dex-cool causing problems?
More than likely your T' stat is causing this, I don't see a reason to go away from Dex if the system is serviced properly and the cap is replaced with a high quality unit, air getting into the cooling system can cause issues with Dex.
maxwedge is offline   Reply With Quote
Old 12-15-2006, 04:49 PM   #3
BNaylor
BNaylor's Avatar
BNaylor +50
Thank you!
Alot of us use Prestone Extended Life. The Peak brand should be similar. Prestone EL is an OAT - Organic Acid Technology coolant just like Dexcool. It is fully compatible with Dexcool.
Just flush out the old Dexcol and start using the alternative coolants.
'08 Pontiac Grand Prix GXP - LS4 5.3L V8
'01 Buick Regal GS - L67 Series II 3800 V6 Supercharged
'97 Pontiac Grand Prix GTP - L67 Series II 3800 V6 Supercharged
Timeslip 08/12/06
AF Community Guidelines
BNaylor is offline   Reply With Quote
Old 12-15-2006, 04:57 PM   #4
jeepgclwj
jeepgclwj's Avatar
jeepgclwj Normal reputation
Not to hi-jack but, I was looking at my radiator fluid level today. What is the gunk at the top of the inside of cap? I hope its not bad cause it look bad.
make it rain on them hoes!!!
jeepgclwj is offline   Reply With Quote
Bookmarks
Google
Web AF
