95 4runner motor swaptyler.winters 12-13-2006, 02:09 PM anyone have an experiance in any v8 motor swap for a v6 2.0... pnoiSR20 12-13-2006, 09:02 PM wth???? V6 2.0?? tyler.winters 12-13-2006, 11:23 PM come on man, use your imagination.... little typo. meant 3.0 pnoiSR20 12-14-2006, 09:53 PM only swaps i heard are the 5VZ-FE engine, 2JZ, 7M-GTE, and also the small block chevy (think 350). fourwd1 12-14-2006, 10:11 PM The most common V8 swap for a Toyota truck is the 350. Search the net for plenty of info on that and other V8 swaps. 4Wheel 12-18-2006, 08:22 AM Check the prices on ALL components needed to do your swap the you have the ECU plus all the peripheral non engine mounted components. Interfaces are what will be your biggest headaches. The ECU HAS to be the exact one for the engine, transmission and versions of all the peripheral sensors. Do you have an automatice transmission? If so it is fully controled by the engine ECU. About the 2.0 vs. 3.0, he was correct in questioning! You HAVE to be that exact when talking this swap you can not assume or guess at anything here and expect it to even start. Just using your imagination will not suffice! When typo can cost you hundreds of dollars in non returnable merchandise and many headaches. Hint: the people here are here to help you, so before you cop an attitude about their response check their title and how many people they have taken their time to help. Just a suggestion for posting anywhere. pnoiSR20 Yes, the virgin never dies, but they are just that, STILL a virgin!! :rofl: Automotive Network, Inc., Copyright ©2012
