Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Toyota > Supra > Performance
Performance Talk about anything having to do with performance & mods.
Old 12-12-2006, 03:18 PM   #1
oldschoolsupra
oldschoolsupra Normal reputation
what all do i need to do to swap an (A43DE) automatic to a manual
i just got an 84 celica supra mk2 it has the 2.8 liter with the A43DE automatic and im getting a TMGTE to put in it what 5 speed tranny should i get to go in it and what all do i need to to swap it out
oldschoolsupra is offline   Reply With Quote
Old 12-12-2006, 06:33 PM   #2
TcmaBoy
AF - Advisor
TcmaBoy's Avatar
TcmaBoy Normal reputation
Re: what all do i need to do to swap an (A43DE) automatic to a manual
I am not sure what the TMGTE is, do you mean the 7MGTE? The 7MGTE should be run with an R154. Make sure you buy a complete motor with harness, sensors, and ECU. If you want to run a manual you should make sure it is a MT ECU. The clutch is hyd, so the car will have to be fitted with a clutch pedal and clutch master cyl set up. You will also have to address the drive shaft.
The W58 trans will mate up to the 7MGTE, and is a better match to your MK II, but it is not as strong as the R154. It will hold up provided you keep the motor stock, and do not drive hard(no hard launches at the drag strip).
Don't you SAS me boy.
Please wheel responsibly.
http://www.treadlightly.org/
TcmaBoy is offline   Reply With Quote
Bookmarks
Google
Web AF
