07 trailblazer
ccopriviza
12-11-2006, 05:43 PM
I just got an 07 trailblazer SS and I was wondering if anyone knew anything about the pnuematic-ish noise it makes from the rear of the car everyonce in awhile when it is idleing????
GMMerlin
12-12-2006, 06:31 AM
This is from that book in your glove box..it's called an OWNERS MANUAL!
Has lots of information about your vehicle....give it a glance over
Electronically Controlled Air Suspension System
Your vehicle may be equipped with an electronically controlled air suspension system that automatically keeps your vehicle level as you load and unload. The system includes a compressor, two height sensors and two air springs supporting the rear axle.
The system also has an internal clock to prevent overheating if the inflator is used for prolonged periods. If the system overheats, all leveling function stops until the system cools down. During this time, the indicator light on the air inflator switch will be flashing.
The ignition has to be on for the system to inflate, in order to raise the vehicle to the standard ride height after loading. The system can lower the vehicle to the standard ride height after unloading with the ignition on and also for up to 30 minutes after the ignition has been turned off.
You may hear the compressor operating when you load your vehicle, and periodically as the system adjusts the vehicle to the standard ride height.
Load leveling will not function normally with the inflator hose attached to the inflator outlet. Remove the inflator hose from the outlet during loading and unloading.
If the vehicle is parked for an extended period of time, some bleed down of the suspension is normal. Upon starting the vehicle, proper height will be achieved.
ccopriviza
12-13-2006, 06:04 PM
hey thanks dickhead. you know i would have looked there except its not my car and as far as the owner of the vehicle knows they did not recieve one.
jozuah
12-13-2006, 07:24 PM
you are a jackass whats this site for man ? your a friggin GM a moderator ? well your smarts are all in your ass you are un-inteligent and this only FURTHER proves your ignorance.
maxwedge
12-13-2006, 07:39 PM
Listen technically this is none of your business, take this to a pm if you feel you have to comment in this fashion, number 2, while labeling people as " unintelligent " watch your own spelling! To add, if we had known this was a 3rd party inquiry, I am sure it would have been handled more directly. Lets back on track here with what has been a very helpful forum for all. Thanks.
BNaylor
12-13-2006, 08:18 PM
jozuah and ccopriviza,
Those comments are uncalled for. No need to flame or revert to name calling. I highly recommend that you both read and comply with AF Community Rules. If you have a grudge against GMMerlin based on his reply then take it via PM or regular email and not in an open forum. Otherwise, please act civilized and communicate without making a personal attack or reverting to name calling. This will be your only and final warning. If you continue with this misconduct and continue to post against AF rules you may get your account banned.
DON'T ATTACK EACH OTHER
Attack the message, not the messenger. Criticize ideas, not the person. Don't attack others. Personal attacks and flaming on others will not be tolerated. Challenge others' points of view and opinions, but do so respectfully and thoughtfully ... without insult and personal attack. No violent, discriminatory language or personal attacks are allowed. Personal attacks are defined as personal, racial, ethnic and or gender based insults, slurs or derisive comments. We reserve the right to edit and remove any inappropriate posts.
# Warnings and Bannings:
Not adhering to these guidelines can result in your account being temporarily or permanently banned. The length of the banning depends on the severity of the guideline broken. During temp bannings a member may not post under any other account. If this happens and it is discovered, all accounts belonging to that person will be banned permanently.
The following situations can possibly get you warned and or your account banned:
1. Ignoring moderator's warnings for any of the items outlined in this document.
2. Heavy personal insults (includes racism, sexism or any other ism's).
3. Campaigning to bring back a banned member, whether in your posts or in your signature.
4. Criticizing a moderator's decision openly in the forum.
5. Making constant attacks on other members and moderators, aka, trolling.
6. You are underage.
7. Post Whoring.
8. Making an Alias Account.
9. Posting pornographic, sexually offensive, sexually explicit or objectively material.
10. Failing to learn from a previous suspension.
11. Impersonating another individual by creating an account that looks very similar to that member or by other means.
12. Having an offensive account name.
13. Scams or the promotion of scams.
14. Advertising other forums when asked not too.
15. Posting of copyrighted material and illegal software.
16. Continuously bumping up threads.
