| Cavalier Problem Diagnosis Got a problem you can't fix? We can help. |
12-11-2006, 11:35 AM
Engine Problem
i was racing with one of my buddies and i was shifting at 5,000 RPM's and all the sudden it smells like burn, so i checked it but i have no idea wats wrong.. but thats not it, first of all, my intake does not sound loud any more, it sucks and it accelerates slow, and last of all it overheats when i ram it, when its parked..?
can any one tell me wats up..!
12-12-2006, 01:30 PM
Re: Engine Problem
this is why racing is bad for you...you break shit...lol pull your plugs see if they look dirty...that is usually one good way to tell
12-12-2006, 01:36 PM
Re: Engine Problem
yeah it's the first thing i was planning to do before anything else, maybe i burned a spark plug...
thanks i will check that and get back to u..
 tHey sAy iM LoCo..! bUt iM rEalLy JuSt A hArdhEaD
12-12-2006, 05:03 PM
Re: Engine Problem
especially when you race little budget economy cars
make sure you're coolant is full
2001 Grand Prix GT: cat/u-bend/resonator delete, zzp PLOG, Custom Intake
1981 Fairmont 6cyl 3 speed
12-12-2006, 05:42 PM
Re: Engine Problem
yeah its only running on water so im ganna empty it and cool coolant on it, and its also weird cause it overheats when im going like 10-20 mph but when im 60+ it goes back down..
12-13-2006, 02:11 AM
Re: Engine Problem
...that is most likely your problem right there.
Water starts to boil at 212 F. The computer waits until 218 to kick on the fan. If you think about it...the water starts boiling before the car tries to cool itself with a fan. You shouldn't be driving, let alone racing, when you are running strictly water...you can really fuck up a car that way.
The reason your car overheats more at 10-20 mph rather than 60 is because cooler air is hitting the radiator at a higher rate at 60, thus creating more of a cooling effect on the coolant (water in your case...tsk tsk) to prevent boiling/overheating. it is vital for an engine to be kept cool...
To put this in to some more perspective...O2 sensors need temps to be above 600F for them to read properly...which means the temperatures can get much hotter than that (granted it is for the exhaust...but guess where the hottest part of the exhaust is? you guessed it...in the engine bay) /RANT
12-13-2006, 10:43 AM
Re: Engine Problem
what if i have to drive to work and im not racing any car that gets next to me anymore..?
work is like a 10 min drive on the street..!
12-13-2006, 01:02 PM
Re: Engine Problem
lol it'll probably be fine for little short trips where you actually do get up to highway speeds...but i would get antifreeze in there ASAP...
12-13-2006, 01:13 PM
Re: Engine Problem
Well Hwy Spped Is Like 75 And Up... Well Heres The Thing, Here Were I Live Speed Limits Are Like 50, 55, 60 And Even 65.. Which Means You Have To Go Fast.. But Im Planning To Flush All The Water Out And Put Antifreeze But The Thing Is That I Dont Have Time Or Money Till The Weekend
12-14-2006, 01:29 AM
Re: Engine Problem
you want a 50/50 mix -ideal- but it could be as much as i think 70/30 antifreeze...either way...never strictly water. just take care of it asap
12-14-2006, 10:35 AM
Re: Engine Problem
thanks for your help..!
