weird problemspeeddevil 12-11-2006, 12:10 AM noticed today that my cars lights tend to dimm when i apply the brake, as i am sitting at a light lights dim car shakes a lil and sometimes the radio shuts off and then comes back on. battery is almost new i have the right cold cranking amps and alternator is fine. what else can cause this problem? silicon212 12-11-2006, 12:17 AM Check your ground from the engine to the car body. speeddevil 12-11-2006, 01:22 AM Check your ground from the engine to the car body. will have to chech that out tomorrow anything else that may cause this? PeteA216 12-16-2006, 05:15 PM Altenator maybe, but if the car shakes as the light dims, then it sounds like the idle's too low. A low idle when the brakes are applied could indicate a faulty brake booster so that when the plunger is depressed it creates a vacuum leak. Use a vacuum testor to see if the brake booster holds vacuum when the brakes are at rest, and engaged. Automotive Network, Inc., Copyright ©2012
