Automotive Forums .com - the leading automotive community online! Visit IgorSushko.com and see what it's like racing in Japan
Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Pontiac > Grand Prix
Old 12-10-2006, 11:05 AM   #1
rlalwardt
rlalwardt Normal reputation
GTP misfires badly
I have a 97 pont. G/P GTP with a bad misfire.A scan of codes revealed two fuel inj. are misfiring. After replacing all six injectors it still seems to be only running on half the cylinders.or with no change.Can a bad crankshaft position sensor cause a false fuel injector misfire code? If not where would I go from here?
rlalwardt is offline   Reply With Quote
Old 12-10-2006, 12:26 PM   #2
BNaylor
BNaylor's Avatar
BNaylor +50
Re: GTP misfires badly
Welcome to AF.
What were the 2 fuel injector DTCs? Any other DTCs? Have you tried a NOID light to check the fuel injector pulse from the PCM module?
A bad CKPS normally gives a no start condition or engine stalling/dying effect once moving. Sometimes a CKPS DTC will set but not always.
BTW - The camsahft position sensor controls fuel injector timing in conjunction with the CKPS.
'08 Pontiac Grand Prix GXP - LS4 5.3L V8
'01 Buick Regal GS - L67 Series II 3800 V6 Supercharged
'97 Pontiac Grand Prix GTP - L67 Series II 3800 V6 Supercharged
Timeslip 08/12/06
AF Community Guidelines
BNaylor is offline   Reply With Quote
Old 12-10-2006, 01:00 PM   #3
rlalwardt
I don't recall the exact DTC's ,I don't have a NOID light .I'll have it scanned again.And repaired by someone more equiped and knowedgable like yourself.Thank You so much for your help though..But this seems to be out of my range of knowledge and resources
Bookmarks
Google
Web AF
