99 tahoe, hesitation, bank 1,2 lean misfire, mapcgworth 12-09-2006, 12:17 AM I have a very bad hesitation when idle and surges really bad. the codes it throws is bank 1 and 2 lean, map sensor, misfire, and i dont know if it is at all contributed but it sounds like a bad vacume leak around the intake but im not sure, i read something about a plenum leak on these 5.7's maxwedge 12-09-2006, 09:45 AM Welcome to AF. Low fuel pressure, clogged injectors, any air entering the engine unmetered, dirty maf, watch for K and N problems as they can contaminate the maf. cgworth 12-09-2006, 11:26 AM Welcome to AF. Low fuel pressure, clogged injectors, any air entering the engine unmetered, dirty maf, watch for K and N problems as they can contaminate the maf. is there any known problems with the intake or plenum gaskets on these leaking? maxwedge 12-09-2006, 02:31 PM It is possible, discharge some propane around the upper intake, this would cause a change in engine reaction, just be careful, obviously Automotive Network, Inc., Copyright ©2012
