engine codedrockg20 09-18-2002, 12:34 PM Can any one tell me what a code 76, 25 and 35 means. Also how to corect the problem i am having? thanks eeyore 09-26-2002, 08:20 AM 76 is the fuel injection system 25 is the AAC valve 35 is the EGR temperature sensor. Sounds like it all needs a good clean up! drockg20 09-27-2002, 06:20 PM how do you clean your injectors or know if they are bad? speediva 10-06-2002, 11:54 AM Originally posted by drockg20 how do you clean your injectors or know if they are bad? Oh, you'll pretty much know if an injector is bad. Mine had a REAL rough idle, and would almost sputter and die at points. Also, the power it used to have in accelerating was just about gone. I'd almost have to pop the clutch at 3000 rpm's to have any get-go out of her... I had to take my car to someone w/a diagnostic system to have them run tests and then replace my #2 injector... But sadly I suspect they botched something else up b/c now I don't pass emissions testing in PA :mad: Automotive Network, Inc., Copyright ©2012
