heat!!
neonneon
12-05-2006, 11:33 PM
1998 plymouth neon 2.0 dohc, when the temp gauge says the car is at a warm temp, in the middle of the gauge, the car blows cold air. it will do this for about 5 minutes then it will go hot, then about 5 more minutes it goes cold any info????
i need heat im in minnesota!!
thanks guys!
KimMG
12-06-2006, 08:57 AM
Check coolant level.
neonneon
12-06-2006, 03:25 PM
If the coolant level was low wouldn't the car over heat in 10 degree weather??
KimMG
12-07-2006, 02:13 AM
Not necessarily, If the coolant level is low, there may not be enough coolant to circulate and you will have air going through the heater core and then a few minutes later you will have coolant circulating through the core.
Ten degree weather will cool coolant in the radiator pretty quickly.
