1997 toyota camrykeilaheartsu 12-05-2006, 02:08 PM i have a 1997 toyota camry and it came with a cassette radio and i want to change it. im trying to figure out how to get the radio out but i cant, can anyone help? Mike Gerber 12-05-2006, 06:51 PM Remove the lighter and the ashtray. Now pull the trim piece up from the bottom near the outside of both sides. Continue pulling up the sides until all the clips are released and the trim piece is out. You will now see the radio held in by 4 screws. Remove the 4 screws and the radio will pull forward. Reach behind and disconnect the antenna and the modular cables. The radio can now be removed. The following link may help: http://carstereohelp.net/Str/Toyota.htm Mike lenjack 12-05-2006, 08:53 PM Be very careful removing the trim piece. It's easily broken, especially if it's cold. keilaheartsu 12-05-2006, 10:13 PM thank you! im gonna try it tomorrow :) thanks:grinyes: popeye08 12-05-2006, 11:23 PM The same: download the pdf file from http://www.installdr.com/InstallDocs/Toyota/Camry.html, very detailed instruction, there is no 1997 model, but actually it will help a lot. Automotive Network, Inc., Copyright ©2012
