F20C1 head swap onto a K20A2...
MJ23FE
09-17-2002, 11:21 PM
I was thinking about getting a RSX Type-S...
If you had a K20A2 (type-s) block and bolted on an F20C1 (S2000) head on to it how would much performance in terms of hp and torque would it gain? The S2000 stock has 240hp & 153 lb-ft tq., and the RSX-S has 200hp & 141 lb-ft tq. in stock form. I read in the same article that the head gasket in both the K20A2 & F20C1 are the same, and this guy named Paulus Lee from AEBS said in the article that the headd should bolt straight on from the F20C1 to K20A2. What do you guys think??? Would that sort of Frank swap be worth on anyone's Type-S??? Is it worth downgrading from i-VTEC to the classic VTEC? Come to think of it, you might be able to brew a turbo setup alot easier for the car since i-VTEC and its new fuel system would be taken out of the picture. Or am i just a complete moron and would changing i-VTEC to VTEC play no part in the way the fuel is delivered? I have this thread posted in the RSX forum and the Lets Get Technical forum but only one person answered it! Please HELP ME!!!
I am seriously thinking about getting an RSX Type-S, i want to know if this frank swap would be possible! If it is not, i would just get the usual upgrades like AEM CAI w/ bypass valve; Comptech Header with a Greddy Evo Exhaust. I also want to drop in Toda Racing Cams, Valve Springs and than get a nice port & polish by means of extrude honing which would also include the intake manifold that would be port matched to a 64mm Pro Flow Design throttle body. If i decide to go FI than i would just forget the header and throttle body and just get the extrude honing or traditional p&p of the head and get the extrude honing of the intake manifold and than wait for my ass to save up for a nice turbo kit!
Extrude honing probably costs... anywhere between a CRAP LOAD and a SHIT LOAD, but with time and alot of saving anythis is possible. Anyone out there willing to touch this subject would be greatly appreciated! Thank you!
P.S. Even if you dont think i will be able to afford all this shit and even though i might know i cannot, please cut me some slack... let me dream!!!
honda troll
09-22-2002, 03:43 PM
If you swap the S2k head onto the K20A bottom, it will not work. Has something to do with the size of the pistons or rods or something.
Thoe99
12-10-2002, 09:43 PM
Even if it were possible, the cost of an RSX-S plus F20C engine transplant would probably equal, if not exceed the cost of an S2000, considering one's FWD and the other's RWD. Why don't you just get the S2000, used or new? The suspension, balance and weight on it far exceeds the RSX-S, and once you transplant it, who knows what other problems may nag you.
MJ23FE
12-10-2002, 10:54 PM
i didnt say i wanted to do an engine swap. i said i wanted to do a head swap. i wanted to know if it could work, and what the performance increase would be. the s2k has regular VTEC while the RSX-S has i-VTEC. now if you did the head swap you would lose the i-VTEC and you would not have the same timing. i am still waiting to see if anyone out there does it. when it happens it is gonna be hella nice. thanks for any replies.
PEACE!
LinearPerformance
07-07-2003, 09:17 AM
Ok so you want to swap some skivvy onto your RSX-S huh? Well first of all just toss the block and keep the head! The RSX head is a very nice flowing head and is perfect for a neo-frank. swap. So why the block you ask? Swap the bottom end from the k24 (The engine that comes in the accord and Element.)...why do you ask? Well that is very simple...it produces more trq than the S2000! (At a much lower RPM level)160 at 4 grand!!!!!!!!!!!
Get a nice intake...get a nice exause and wait for a turbo kit for the accord to come out..you will spank anything that pulls up next to you.
The only hitch so far is that you have to either wait for Hasport to make a mount kit for the k24 for your car OR have it custom welded in. The options are yours. BUT I can promise that its better than your first idea. The compression on the s2000 is off the wall and couldnt handle a turbo kit...those that say they have good turbos for it just want to snag some money from you.
My shop is in the process of taking an RSX-S head and slapping it onto a k24 bottom end... the car it will be going into is my 2001 civic dx. See ya at the track.
LinearPerformance
07-07-2003, 09:19 AM
(And ohhhh yeah...you will be keeping your I-VTEC which is a beautiful thing. Look into going to Hondata.com ..they have a flash programed RSX-S ecu that gives you 20 more HP just by working the RSX codes in the brain!!!!! Forget the s2000...they are junk!)
David Kang
07-23-2003, 05:22 PM
Hmmm....sorrie but the S2000 is not a junk.
LinearPerformance
07-23-2003, 05:55 PM
Sure the S2000 isnt junk....if you are an old man with a limp penis. That car is rear wheel drive... its crappy gas and the compression is to high for a high PSI turbo or supercharger. If you like that car... you truly know nothing about racing...you must just be a car lover in general. If you dont like what I said...tough... get over it.
David Kang
07-24-2003, 12:42 AM
Actually I own a Honda S2000, and I know for a fact that it isn't a peice of junk. Actually its a very nice sports car with good top end power. Tell me any other car that is Honda or Acura that can rev all the way up to 9000 RPM straight from the factory. Yes the Honda S2000 is rear wheel drive but someone people actually prefer rear wheel drive over front wheel drive. Some people like FRs and some people like FF personally I love the FRs. They give better start off the line I think. and another thing, how do you know that I know nothing about racing. Spoon sports made a racing S2000 and it is very fast. Now if the Honda S2000 was a piece of junk, why would a respectable company like Spoon Sports use it??? I may not know a lot about racing, but I do think I know a little bit enough to say that your wrong when you say that the Honda S2000 is a junk.
blasian_man
07-24-2003, 12:47 AM
uh. . . does anyone remember when they track tested a stock s2000, a spoon sports one, and a jackson racing SUPERCHARGED one? i think it was in scc magazine
LinearPerformance
07-24-2003, 12:48 AM
Just so you know Spoon sports will make parts for everything they can so they get MONEY. They make parts for the honda CRX... which isnt that fast with the stock engine. Unless you do more work than the car is really worth. Second of all the HONDA S2000 isnt the baddest car Honda has made. Infact must I remind you about the NSX?
It wont be to long before the S2000 is gone...mark my words. Its also pathetic how the s2000 with a 2.0 4 banger gets worse MPG than the Vette ZO6...infact I think its REALLY pathetic.
You can back your rolling mistake all you want... My 2000 civic Si gets better MPG and out runs S2000s all the time. Thanks to good ol know how and street smarts. Enjoy the gas prices pal! HAHA
David Kang
yea I remember that car. Actually I have the poster up on my wall right now. +) Love that S2000
blasian_man
07-24-2003, 01:02 AM
would anyone else like to see linear's civic?i know i would. if it can beat an s2000 that's a bad ass machine
and if it CAN beat a 2000, then that means you've also put more work in that the car is really worth.
LinearPerformance
07-24-2003, 01:18 AM
I put very little money into my car. Infact I just gave it some time. It can beat an S2000 because I know how to make a car go fast. Note ...its a 2000 Si! not a CRX! Anyone with half a brain and 4 grand could make a crx run 11s in the quarter mile...all motor too. Its called an H22a.
My CIVIC isnt all motor....but it is a very nice setup. If you want to see it then maybe I will grant you that wish. If you show respect.
blasian_man
07-24-2003, 01:21 AM
:useless:
well now that you've claimed it, you'll surely be able to prove it right???
LinearPerformance
07-24-2003, 01:37 AM
First thing tomorrow you will have all the pics you want. I will even take fresh ones for you!
blasian_man
07-24-2003, 10:36 PM
not to be an asshole or anything but where are your pics? did you start another thread with them? other wise im gonna have to cALL:bs:
WongGahming
07-27-2003, 08:20 PM
i would agree this thread it worthless with out pics, maybe some dyno charts, maybe some engine pics.
second there are many good company's that make turbo's and superchargers for the S, Vortech and comptech make superchargers for the S that have proven 100whp gains at only 7psi, spool and ulitimate-racing provide tested turbo's for the S also running at a little less 6psi but still producing jsut about the same amount of power.
also i do grant you props if you can get your Si tunned up to beat a stock S that is a good accomplishment, but in my area about half the S's are now either super or turbocharged. why don't you roll down to maryland and play here. Also there is a gentleman in Florida with a 500hp S2000 granted not at the wheels but 400whp is not out of the question. When more parts come out for the S2000 prices of Sc/T kits will decrease making tunning S2000 less costly. this is also a reason why it is cheaper to get more power out of say civics because of cost compitition.
I'm personaly glad i have my S. but props for you for taking your car to its max. ON the FR, FF battle give that up its all personal tastes, i like FR cars more personaly because im big into drifting and its just alot easier to swing that back end out with FR its all personal tastes my friend.
happy tunning
S1 Type-R
08-16-2003, 07:37 PM
LinearPerformance I think your full of shit and a big shit talker.....Talk the Talk but the ones that can never walk... :loser:
LinearPerformance
08-16-2003, 08:20 PM
Why should I even bother proving anything to some jackass like you? You are the proud owner of three rolling piles of crap! You want me to prove what I have then show up at a strip sometime and see it for yourself. If you have any more smart ass comments save them for your mommy when she asks you to clean up the family car you pretend is yours. Bitch :screwy:
blasian_man
08-19-2003, 08:40 PM
i have to disagree, he's got pretty decent cars. but why do you have so many similar cars?
you two are on opposite sides of the country, why would either of you drive 1000's of miles just over a dumb argument? just post some pics and put out the fire.
94tegRS
08-25-2003, 01:05 AM
he has a 99 SI, dont you have a 2000 SI? so you think your car is a rolling pile of crap, makes me wonder why you bought it? :screwy:
and sounds like the excuses of a kid pretending to have a S2000 whoopin civic if you ask me :thefinger
90CRXZCSi
09-19-2003, 01:26 AM
get a life. little 14 year olds shouldnt be shit talking over the internet. your mommy and daddy might get mad.
~ls/vtec~
11-03-2003, 11:16 PM
LinearPerformance go back to the girl racer forum bitch. my bro couldnt pull a fraking s2k on his moded gsr, and he spanked hella si's. so shut up or back ur words up. "i pulled an s on my si." :rofl: i laugh in ur face bitch. :thefinger
now if i figure out how to post pix on here ill post a pic of something that will spank ur si over, and over.
ALLMOTORPACMAN
11-23-2003, 12:34 PM
Mr LinearPerformance
I have a S2000 All motor And I would love to race that si you guy's are talking about that bit an S2000 :evillol:
http://images.cardomain.com/member_images/9/web/381000-381999/381350_33_full.jpg
http://www.imagestation.com/picture/sraid89/p92fc3a052c30c74394e1cb26877f3128/fa80809d.jpg
Thats my car at HYTECH :ylsuper:
I will be salling a set of the itb's for the S2000, k20 and B.. engines
soon.
pm me if anyone is interested
mx3man
11-22-2004, 01:29 PM
LinearPerformance, you get five out of five from the Redliners board, we salute you!
http://www.redliners.ca/iB_html/non-cgi/emoticons/tapdat.gif http://www.redliners.ca/iB_html/non-cgi/emoticons/tapdat.gif http://www.redliners.ca/iB_html/non-cgi/emoticons/tapdat.gif http://www.redliners.ca/iB_html/non-cgi/emoticons/tapdat.gif http://www.redliners.ca/iB_html/non-cgi/emoticons/tapdat.gif
ridestreet84
11-23-2004, 03:24 PM
that has to be one of the best looking engines i have seen in a s2k many many props to you man
