rear struts 1992 camryjohnson110 12-03-2006, 07:38 PM Question, How and where do you get get at the rear struts out of a 1992 camry, I see the twon bottom bolts that hold it in but where are the top bolts and how do you remove them ! Thanks for any replys!! odie1 12-03-2006, 11:26 PM Johnson110, You remove the rear seat. I did my 94 and its not that much trouble. The bench just lifts out, then there is 1 bolt holding in the "wing"...the edge padding of th eupright, then a couple of screws that hold in the "cover"... over the speakers. That gives you full access to the top of the strut. Takes about 10 minutes..... 5 after you have done it once... I think you're 92 is the same as the 94, If not, I apologize. Odie1 RIP 12-04-2006, 01:12 AM This doesn't tell you much more but, it has a couple of pictures of the upper mount. Scroll half way down. http://www.autozone.com/servlet/UiBroker?ForwardPage=/az/cds/en_us/0900823d/80/13/f6/61/0900823d8013f661.jsp JOET/CAMRY 12-04-2006, 03:34 PM I think you're 92 is the same as the 94, If not, I apologize. 1992 - 1996 ( third generation camry ) should be the same setup.:2cents: Regards, JOET/CAMRY Automotive Network, Inc., Copyright ©2012
