Automotive Forums .com - the leading automotive community online! Visit IgorSushko.com and see what it's like racing in Japan
Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Chevrolet > Blazer > Problem Diagnosis
Old 12-03-2006, 10:37 AM   #1
lynndiwagon
lynndiwagon Normal reputation
Vacuum Actuator Tee Switch
Just got through checking out my front Diff. vacuum actuator. It's OK. Anyway, there is a "vacuum Tee" right before it goes to the acutator that has a stub on it with some sort of switch on the end. I think it is a switch because it has a wiring harness connected to it. My question.....What is this for? I've already determined through you guys that my problem with the actuaor not releasing after returning to 2HI is the vacuum switch on the xfer case.....thanks for that one.
Lynn Wagoner
Yukon, OK
lynndiwagon is offline   Reply With Quote
Old 12-03-2006, 01:22 PM   #2
laxman21
laxman21's Avatar
laxman21 Normal reputation
Re: Vacuum Actuator Tee Switch
Got me? Can you take a picture of it?
'92 s-10 4x4 EC p/u
'99 Blazer LT
'99 Suburban LT
laxman21 is offline   Reply With Quote
Old 12-03-2006, 04:12 PM   #3
muddog321
AF -Advisor
muddog321 Normal reputation
Believe you had the 3 buttom case so a 233 and if you mean on the transfer case 2 electrical things on it - the VSS or speed sensor and the 7 pin encoder motor connector. If you mean under hood then the T has a one way little plastic valve and then off to the Transfer and the plastic line to the heater controls.
muddog321 is offline   Reply With Quote
Old 12-03-2006, 04:52 PM   #4
lynndiwagon
Thanks for the reply, this thing is right by the battery....I will take a picture for you guys as soon as it warms up a little.
Old 12-04-2006, 05:29 AM   #5
muddog321
AF -Advisor
Under the battery tray is the font vac actuator - vac from the 3 port switch on 233 case is activated and that pulls a diaphram in that front actuator that in turn pulls the cable to the front axle coupler engaging the right side CV axle so now 4Hi (or 4Lo) can drive the front end. There is also a sensor with 2 wires on the front coupler to tell the TCCM its position.
Old 12-06-2006, 01:07 PM   #6
lynndiwagon
OK, here is the picture. The switch in question is the one with the green connector. This vacuum stub goes to a "Tee", one leg to the xfer case vacuum switch and the other side to the vacuum actuator under the battery. Maybe a vacuum sensor for the 4WD computer???
Bookmarks
Google
Web AF
