2001 325i service engine soon lightsmokey27 12-03-2006, 10:28 AM What causes this light to come on. I would like to reset it. Is there a way? Bear 12-03-2006, 04:06 PM you need to have the car code scanned and Auto Zone should be able to do that for free on your car. A scanner can reset the light, but it is wise to know why the light came on. venzon 12-04-2006, 01:05 AM This light reminds you that the car is due for service. I found the instructions below on how to reset the light. I've never done this manual procedure since I have the reset tool but try see if it works. Good luck! To reset the indicator: -The car should be off -hold down the left instrument button (the trip odometer reset) -while holding the key, turn the ignition to position 1 (radio) -you will see a test menu -keep holding the button -after maybe 10 seconds, the word "reset" will appear -let go of the button and press again -THe indicator is reset! abrittis 12-04-2006, 10:36 AM Hello Venzon, What you described is how to reset the maintenance interval. The problem that smokey27 is having is due to a problem with an emissions system component. The only way to reset this is to identify the problem with an ODBII scanner, fix it, and reset the code with the scanner. Anthony This light reminds you that the car is due for service. I found the instructions below on how to reset the light. I've never done this manual procedure since I have the reset tool but try see if it works. Good luck! To reset the indicator: -The car should be off -hold down the left instrument button (the trip odometer reset) -while holding the key, turn the ignition to position 1 (radio) -you will see a test menu -keep holding the button -after maybe 10 seconds, the word "reset" will appear -let go of the button and press again -THe indicator is reset! venzon 12-05-2006, 01:58 AM Oops, you are right I apologise. smokey27 12-05-2006, 11:39 AM Thanks for the info I'll try the scanner blu330i 01-06-2007, 11:14 PM I say take it to the dealer you might throw the sensor off track, mines comes on because of the cold air intake and the chip that was put in by the Diani group, and it's been coming on and i'm getting tired of it. everytime i give it so speed it comes on. I drive a 330I four door BMW . jaydv 02-17-2007, 12:12 PM Venzon, just a note to say "thanks" for telling us how to reset the oil maintenance warning! Worked like a charm! Friggin' BMW wants to charge $50 plus to reset this silly thing!!! venzon 02-17-2007, 01:20 PM You are welcome jaydv. I still would like to know the outcome of smokey27 service engine light issue. meromance 01-09-2009, 07:06 AM My Engine Light came on as well took it to get scanned and they said its the Oxygen Sensor cost me $180 from the Dealer. Automotive Network, Inc., Copyright ©2012
