Automotive Forums .com - the leading automotive community online! Visit IgorSushko.com and see what it's like racing in Japan
Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Volkswagen > Eurovan/Multivan/Caravelle/Transporter
Old 12-02-2006, 05:50 AM   #1
Vanagon-tom
Vanagon-tom Normal reputation
Battery drain test?
Would this test work to test for battery drain?
Disconnected the negative on the battery, hook a test light to the negative post on the battery and the negative battery cable. Take out one fuse at a time to see if the test light gets brighter. If the light gets brighter, you know what electrical system is shorting to ground. Will this work?
To see if its the altornator not charging, disconnect the negative to the battery, if the vehicle dies, then the altornator is bad, is this safe on the altornator or is there a better way to test the alternator?
Thomas
Vanagon-tom is offline   Reply With Quote
Old 05-17-2007, 09:16 PM   #2
bakertools
bakertools Normal reputation
Re: Battery drain test?
I am having a similar battery drain issue in my 2003 Jetta that just started. Did you ever figure out what was causing your trouble? I have a post going for my problem and the testing that I have done.
Easiest test for alternator is to test across the battery with it running and it should be reading above 12v and steady. probably up in the 14v range.
bakertools is offline   Reply With Quote
Old 07-06-2007, 03:17 PM   #3
rogue13
rogue13 Normal reputation
hello the best way to test for a drain is diconnect the earth side of the battery connect the test light between the earth cable and the earth sid eon the battery now the test light will light up if you have a drain, now if you take each fuse out one by one if light does not go out replace that fuse untill light goes out. the only other way that you might have a drain is if you have an immobilizer fitted as some of them wont show up a drain the test light way good luck
rogue13 is offline   Reply With Quote
Old 07-06-2007, 03:20 PM   #4
rogue13
to test the alternator you need to get to the back of it and use a multi meter connected to the live side and the black wire on the multi meter to earth this should give you a reading that is right out of the alternator
Thomas
Bookmarks
Google
Web AF
