Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Toyota > Supra > Performance
Performance Talk about anything having to do with performance & mods.
Old 12-02-2006, 06:35 AM   #1
mr supra
mr supra Normal reputation
Turbo Question
So a friend of mine has a set of stock turbos off of a MK4. He only wants $300 for them. I have a MK3. I was wondering if they would work well on my 7M. If so should I do a twin or single turbo set up? I'm not looking for massive horsepower. All I want is something a little more fun to cruise.
mr supra is offline   Reply With Quote
Old 12-02-2006, 02:27 PM   #2
TcmaBoy
AF - Advisor
TcmaBoy's Avatar
TcmaBoy Normal reputation
Re: Turbo Question
The simple answer is no. If all you want is a small bump in power then get a boost controller and piggy back fuel controller. When you do your fuel tune you should use a wide band AFR monitor to do the job. The stock narrow band isn't sensetive enough for tuning. You can push things up a bit, say 12-14 psi, and be ok. Make sure that you get an after market boost gauge to keep an eye on things. The stock one isn't up to the job.
Don't you SAS me boy.
Please wheel responsibly.
http://www.treadlightly.org/
TcmaBoy is offline   Reply With Quote
Old 12-02-2006, 07:04 PM   #3
mr supra
Re: Turbo Question
Thanks for the advice. All that stuff wuold be great if I had a turbo already. Sorry, forgot to mention that this is going to be on a 7MGE. If I'm were to turbo my non-turbo would these CT-12 turbos would well as single or sequential, or would using a stock CT-26 be better. I also found a garret T-25 ball bearing turbo for Ithink $600 or $700. I don't have a lot of money, but I do have time, patience, another car to drive, and a friend that is an awesome welder and fabricator. Any help or insight on these turbos would be great.
Old 12-02-2006, 07:14 PM   #4
TcmaBoy
AF - Advisor
TcmaBoy's Avatar
Re: Turbo Question
Just swap in a 7MGTE and be done with it. They run about $900.
Old 05-07-2007, 01:29 AM   #5
laxd-out
laxd-out Normal reputation
Re: Turbo Question
Hi all
im in the process of putting my 1g-gte into a 1983 toyota celica and i wnt to change the twin turbo to a single turbo wots the easiest way and a ruff estimate of how much???
laxd-out is offline   Reply With Quote
Old 08-19-2007, 02:05 AM   #6
alexcarmichael20
alexcarmichael20 Normal reputation
Re: Turbo Question
i got a 7mge at www.venus-auto.com for 400 bucks. just used the block and pistons and the rest was all 7mgte. came out pretty good all together
alexcarmichael20 is offline   Reply With Quote
Old 08-19-2007, 12:37 PM   #7
TcmaBoy
AF - Advisor
TcmaBoy's Avatar
Re: Turbo Question
Don't crank up the pressure too high on that set up. The 7MGE has higher compression pistons that the 7MGTE, and will not be happy if you do.
Bookmarks
Google
Web AF
