idle problems
Google
Web AF
power453c
09-17-2002, 03:04 PM
I have an 1986 f150 that is having trouble idleing. If I don't put my foot on the accelerator within about 30 seconds it will die. Also the other day I had to hit my brakes harder than usual. This did not allow the transmission to shift gears and It died. As Long as I have it in gear it will usually hold itself at around 400-600 RPMsonce it gets warmed up. This machine has throttle body injection. and a 302 cu in. 3 speed automatic with overdrive. Can any body tell me where to start looking to fix this problem.
wrench_head_77
01-07-2003, 05:21 PM
Sounds like the same problem that I'm having.
Even after the truck is warm, it still seems to idle too slowly.
See "87 F-150 EFI idles erratically" on this forum.
Maybe we'll get a reply soon.
w_h_77
wrench_head_77
01-21-2003, 10:48 PM
I changed the EGR valve. No help.
After consulting a ford owner friend, he suggested replacing the Idle Air Control Valve--also called the Idle Bypass valve.
The Haynes manual shows how to test it with an ohm meter.
Eureka. It is fixed.
Part costs about $65.
W_H_77
Google
Web AF
