Our Community is 940,000 Strong. Join Us.
Carbon Fiber Hood
RX7FD
09-16-2002, 09:18 PM
Im almost done with my Tamiya R32 with engine detail, the hood is clear so i was thinking to tape a mesh on to it and spray it, but will this work with a spray can? and does anyone know where to get really fine mesh in the chicagoland area? Or should i go and buy carbon fiber decals?
TheSyndicate
09-16-2002, 09:38 PM
If you've mastered the mesh method, then why not? But carbon fiber decals might be less of a hassle.
935k3
09-16-2002, 10:15 PM
I don't think a spray can will work to well. Check out the latest issue of
Model Cars magazine, there is an article on doing a carbon fiber hood with Scale Motorsport decals.
Lownslow
09-17-2002, 12:03 AM
Check Stantons by Lawrence and milwakee(havent been on this street in a while so i dont know how to speel it right) they should carry it if not i can get you some from Past Time hobbies but it aint no where near Chicago
Snooker
09-17-2002, 10:37 AM
Originally posted by 935k3
I .... Check out the latest issue of
Could you scan and post that?
Guido
09-17-2002, 10:46 AM
I wouldn't use the spray can, since you'll need to spray the paint in very thinned fine quantity. I don't think you can get that effect with a spray can. The airbrush can do that. If budget is not an issue, then go the CF-decal way ;)
flyonthewall
09-17-2002, 12:16 PM
http://files.automotiveforums.com/uploads/5142681.jpg
Here's an example of CF decal. I think it looks quite convincing and when it's had a gloss coat it will look even better. This pic was taken a few days ago when the decal was first applied and has since had the areas around the vents cut out.
lotus_man
09-17-2002, 03:26 PM
I'd say use decal, no question. Scal Motorsport stuff is brilliant, but you do need to use decal solution on it. I have a part finished 911GT1 prototype from '96 completetly covered in the stuff, which sounds like a nightmare but actually wasn't that bad. the problem is, it confuses the hell out of my digital camera when I try and photograph it!!!
Luka3000gt
09-17-2002, 03:34 PM
Hey fly; how do you cut the carbon fiber decal on the vents cut?
flyonthewall
09-17-2002, 05:09 PM
I basically just punctured the area with a blade (the decal was completely dry) and applied generous amounts of decal solution to make it fold over the edges. The louvres had fresh pieces of decal applied. I will try to post a pic of the finished hood tomorrow.
RX7FD
09-17-2002, 05:29 PM
Thanks for the help guys. Where can i get this decal solution, and do the wirkles over the vents disapear when decal solution is applied?
RX7FD
09-18-2002, 08:56 PM
Hey, Flyonthewall what kind of decal solution did you use on your carbon fiber hood??
flyonthewall
09-19-2002, 06:28 AM
I used Microscale MicroSol - awesome stuff!!! I did manage to get a couple of wrinkles in the decal but i'm not worried adout them coz this isnt going on any model.
http://files.automotiveforums.com/uploads/2199155.jpg
http://files.automotiveforums.com/uploads/7246516.jpg
