CRX d16z6/d16a6 swap distibutor/timing helpLittleREDM&Mcrx 11-27-2006, 08:37 PM Okay I just bought a CRX with the mini me swap. The car has a clean swap with correct ecu jumper harness. Heres my dilemma. If the car has the D16z6 head on it, do i need the D16z6 distributor because the car will run but will kick in the rev limiter at 3grand. I toyed with the distributor and tried to center it but everytime i did the car would only reach 4grand once i floored it. Then I returned the distributor to the position that it was before which was pushed forward but had the same problem again the rev limiter kicks in a 3grand and i loose power. help please 92CivicFoDo 11-28-2006, 12:58 AM if you are just running an ECU jumper harness then you still need to use the OBD0 disty. your best bet might be to just get a PR3 ECU and keep it OBD0 and run the wires for vtec and such to the ECU. LittleREDM&Mcrx 11-28-2006, 06:48 PM the head on the car is D16z6 obd1 and the ecu im using is p28 so i have to use a distibutor of a d16z6 cuz the distributor should match the head. the harness goes from obd0 to obd1.......????? Automotive Network, Inc., Copyright ©2012
