1992 Doge Dakota GaugesJIMTON 11-24-2006, 11:16 PM I Have A 92 Dakota.the Small Gauge Cluster(gas,oil,water, Ect.) Do Not Work At All. Does The Dash Insert Need Changed Or Is It A Ground Problem. rhandwor 11-29-2006, 08:45 PM I would suspect the ground be checked out first. Ohm from the ground conn. in the panel to a good body ground. It should be close to zero. gitrdonedakota 02-09-2007, 10:43 PM i have a 93 dakota that had a ground problem in the dash. check that Automotive Network, Inc., Copyright ©2012
