how to adjust idle up solenoid (SV2! Camry)matik07 11-24-2006, 08:19 PM Have 1987 sv21 camry. Have replaced the idle up solenoid but my mechanic adjusted it because it was set too high. Now it has no effect. How do I adjust it so it increases the revs. ALSO how do I increase the engine idle as it always sits on 600 and can cut out on acceleration. what should it be on an automatic? Thanks ProMan 11-24-2006, 10:21 PM The idle up VSV is not adjustable. It's just a valve, open or close, to control the air flow. Follow the air tube, it connects to another valve with a white hex top and a spring. That's what you can adjust. matik07 11-28-2006, 02:33 PM Thanks Proman! Idle much better with air con !:wink: The idle up VSV is not adjustable. It's just a valve, open or close, to control the air flow. Follow the air tube, it connects to another valve with a white hex top and a spring. That's what you can adjust. Automotive Network, Inc., Copyright ©2012
